I've recently pick up an 07 LC, no check engine light and runs fine.
While inspecting engine bay I notice gunk build up on outside of each lower intake ports. Both head cover seals look tight so I don't think much if any oils coming from them. I've seen this on every (only 3) VVTi plastic intake I've seen. Anyone else notice this?
I pulled the intake manifold last night. I actually remove bolts a few days ago, then let it sit until I got back to it. I did lift an let sit back down several times while pulling off (hung up), but never past the guild studs. So each time it would settled in same spot. When I did final pull the manifold I notice what may be leaks. Noticing how much oil is in area, I assume is from PCV valve. I'd consider this normal but it could be why intake ports collect so much gunk on outside of ports. By this I mean as engine cools over night oil seeps out seal of intake to head gasket. The head & intake mating surface are very oily outside gasket seal area. But I did not get off quickly or in one smooth move, so not conclusive.
What do you guy's think this is sign of leak?
Did Toyota design this as expectable?
Does the intake plastic expand with heat like the metal of the heads?
Could this have anything to do with issues (P0420 & P0430) you're seeing?
Port #3 and #6 looks like possible leaks at operating temp. I say this because of blackness of gasket on outside. Could these be clues of intake leak(s). Although #3 & #6 could indicate when at operating temp as well, or may just be from my pulling off carelessly. I think this warrants a vacuum test when cold as well at operating temp, on those that have not replace intake gasket. Not sure how good a test would be cold with RPM so high, or how you'd do that.
These extra black could be from my sloppy removable, but keep in mine it settle in same spot each time. So I don't think any grim not already there was introduced. So very like it was there before I loosen bolts & pulled on intake.
If there is a next time, I'll pull off fast in one move.
