First, thanks to all the excellent information on this thread! For my '97 LX450 I've done my best to follow all the advice (disassembling and cleaning the upper intake manifold, etc.) and am down to checking individual components. In the FSM, when checking the EGR valve one step is to put a T splice into the hose from the EGR valve to the EGR modulator to connect a vacuum gauge, and then take the hose from "Port R" on the modulator and feed it into the intake manifold. The FSM says that under these conditions, a hot engine, and 2500 RPM, one should see "high vacuum" on the gauge. Under these conditions my gauge says 6.5 in. Hg vacuum and what I would like to know is if that is "high vacuum", or if not do I have a problem with the EGR modulator or valve. Many thanks in advance!
-Throttle Body Gasket 22271-66010
When I got my PO401, I replaced the vacuum modulator valve with the new type ($65)...nope. I replaced the VSV for EGR ($73)...nope. Took apart the EGR valve, cleaned and re-installed...nope. Finally, (and I tell this story just to suggest reversing the order of troubleshooting per super90) I cleaned the little vacuum port that goes into the intake with a piece of stiff wire. I thought it went into the intake, but it actually goes THRU the intake, so use a long piece of wire, and disconnect the hose connected to the other end of the port under/inside the intake (sort of hard to access) before you start cleaning. I cracked the flux off a piece of 7018 welding rod and used it to clean with, because it is stiff and straight. I used a drill bit first, before I realized how long the vacuum port tube was. For me, this was the fix. Have not had a PO401 in the 2 years since. If I had tried this first, I would have fixed it for free. Instead, I have a nice supply of back-up parts should either of them fail (for $138 )
Hey Guys... fighting the good fight against the 401 code... looking all over but, could not find where this port actually is... any help with pics?
Post number 4, Here:
P0401 Defeated - with pics
That would be a first step if you don't want to get into the EGR and vacuum systems right away. Have a new TB gasket on hand, they are inexpensive.
Po401 fixed with relay and resistors.
1k-4k resistor at radioshack is a few bucks.....
Any ideas/suggestions before I throw in the towel?
