- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
- Thread starter
- #61
The BH and clutch must be installed w/ engine hanging from the crane. Then the engine can be set gently on a piece of plywood, then tranny & t-case are scooted up against BH and carefully maneuvered into place. The use of an engine tilter and some miscellaneous wood blocks helps a lot.
No, getting the e-brake off will be impossible w/ out either: lowering the rear of the engine or cutting out the x-member.
So install a new pair of shoes and replace the cable if at all questionable, then install the whole unit into the truck. Because you've antiseezed the P-brk works and replaced wear parts, you will not need to get in there for another 10-20 years.
Well the shoes are mostly new, all internals stripped, powder coated, greased and reassembled. The speedo housing has the double seal mod and the e-brake cable is pretty new. My only concern about the cable is will it reach now? I have heard a 1974 cable is longer?
I still believe the best long term fix is to cut out the cross member and make a bolt in version if it. It will be easy with the body off...
I have a press...
