Need help figuring out this leak. Back side of the engine.... how big of an issue is this?
HM oils like Mobil 1 High Mileage have seal modifiers added in. So are you also saying don't use these? Can you point/link to any research/evidence of this?Don't try any re-sealer. They are the worst thing you can do unless it's a $1500 clunker car you need to sell. They Swell the rubber seals to stop the leaks like rice absorbing water. This affect works short term but it also swells other seals. Then they lose their puffiness after a little time and the leak will come back twice as bad and you'll likely develop more weeps in other areas
I've been rooting around looking for some solid evidence of what these seal conditioner/modifiers do long term, I'm not finding much hard research. I've spoken with ATP tech support, they state run with AT-205 for minimum of 5 hours. After which you never need again and can leave in or flush out. Mobil tech states; you need to keep using the M1 High Mileage oil if you done two or more changes (~8K to 16K miles) with it.I was talking about concentrated products such as "Lucas Oil - Stop Leak". I cannot speak for high mileage oil.
What sort of evidence are you hoping for mate? I can only give you my personal experiences as a former used car manager and common sense. When using products like that it targets all the seals, not just the weeping one. The seals swell, even though they may have been completely fine, all in the aim of stopping one particular weep because it was either A; financially unviable or B; The owner is a cheapskate.
After a period of weeks and sometimes months the weep comes back again, equal or worse than before and often times other seals now begin to give way because they have been exposed to the product. Temporarily swollen and now once again deflated.
You begin to have to use the stop leak more frequently, like a person addicted to botox or steroids. Let's face it, if you're using a $15.99 bottle of Lucas stop leak to fix a rear main seal on a cruiser instead of ponying up to get it done, you should probably be looking to drive a camry.
These are precision instruments and require the maintenence their durability is beholden too. If not, it's a slippery slope downhill.
But that's just my two cents. Take it or leave it as you will. I'd be interested to see if anyone else has some good reading on the stop leak products.
I agree keep PCV valve in good working order or you'll blow oil from weakest spot.#1: If you haven't checked/cleaned/replaced your PCV valve now is a good time to it. Increased bottom end pressure will only exacerbate the main seal leaking issue.
#2: Had the same leak at ~245k. Robbie, while I was in the Denver area a couple years ago, put a new main seal in along with a new flex plate (ticking time bomb on the 2UZ-FE).
You might get away with running thicker viscosity oil to slow the leak. For awhile.
That's absolutely a rear main leak. If you want to solidify your diagnosis, take that plate off and look up into the bell housing with a flash light.
Oil leaks only get worse. But that doesn't look bad at all. No one likes to fix rear main leaks because it's the cost of R&Ring a transmission.
I would keep an eye on it. Once it starts using oil or bathing the underside of your truck, then it's time to worry.
This is coming from a Technician
As been stated here your looking at a potential rear main leak. How big and issue depends on how bad it's leaking. No leak is acceptable to me.Need help figuring out this leak. Back side of the engine.... how big of an issue is this?
