FrazzledHunter
I'd worry that I didn't hit the bottom of the pan.This pump has on the intake side a hose with like ~5mm diameter. Goes down easily the dipstick tube.
Do it the first time then pull the plug to see if any more comes out. If not, mark that depth on the suction hose and future changes will get that amount.I'd worry that I didn't hit the bottom of the pan.Is it easy to tell if you have the intake hose down far enough? I guess you could measure the volume of what you pump out.
Just put him in deeper than your measure rod and then let it pump. When you see the pump sucks air, push deeper, wait till pump sucks air, push….I'd worry that I didn't hit the bottom of the pan.Is it easy to tell if you have the intake hose down far enough? I guess you could measure the volume of what you pump out.
Can’t go wrong with Genuine Toyota or even TRD. The former are even under $5 at dealer discount sites and simply can’t be beat for build quality.What Oil filter brands have people been using?
I had a box of TRD PTR43-00081 .. but just ran out, so I need to re-stock.
Whatever oil filter fits… if you getting some kind of known brand you never go that bad. Especially when you do like me a oil change every 6kkm with the cheapest oil I’m able to find and that fits the Toyota specs for my diesel.What Oil filter brands have people been using?
You may not feel a difference but the oil filter being high quality is critical.Whatever oil filter fits… if you getting some kind of known brand you never go that bad. Especially when you do like me a oil change every 6kkm with the cheapest oil I’m able to find and that fits the Toyota specs for my diesel.
Never noticed any different behavior no matter if expensive high end filter or cheap. It is not rly that much like with air filters where you can feel differences.
But that underlines the statement...You may not feel a difference but the oil filter being high quality is critical.
The metal support tube inside the element should keep the filter material from passing into the oiling system if it fails, but I don’t want to trust my engine to “should”
There are documented cases of well-respected filter companies trashing engines. Like one write up I read about a wix filter on a 1FZ.
The Genuine Toyota filter is paper made in Thailand if I remember correctly, but their quality control is the same as used building their vehicles and as a result likely higher level than even name brand aftermarket offerings.But that underlines the statement...
The brand filter can also fail in the same way. In the end, most filters that are not necessarily sold absolutely no-name somewhere on ebay come from a few dozen factories that simply process orders from the filter brands or car brands.
(There are also people out there who believe that even one employee of Red Bull or Monster, for example, have ever held a can in their hands in production).
The 17$ TRD filter did not use any other material than a filter from Mann for 12$ or one from Bosch for 10$ except that it generated 5$ more money...
Of course, you should not use the filter paper that was pressed together somewhere in Pakistan and sold for 99ct but that should be clear to everyone.
But it doesn’t have an R for Racing!I have been using OEM Toyota paper filters since day one, absolutely no reason to spend more on anything else IMHO. Readily available, cheap, designed for the vehicle and they work well, onward.
Factory filters fit snug on the metal support tube but don't "snap" on or anything. As you reinstall the cap the spring in the base pushes the top of the filter against it's flange.. done.But of a SQOD question…. I just finished my first oil change after ditching the dealership.
Does the oil filter need to snap into the oil filter housing or do you just place it in there? I put a little bit of down force on the filter, but it gave with the spring in the bottom.
