No experience with either. Based on the picture, the way to valve sticks down it looks like it could grab something and potentially try to tear out if that makes sense. Kind of damage multiplier. It sounds like there is a shorter option that may help alleviate that concern. Doesn't appear to have a magnet either so how can one catch and then inspect for metal?
As for an oil extractor, I doubt you will get all the oil out of the bottom of the pan where contaminants concentrate resulting in a lack of ability to get a good visual inspection, especially for metal.
I also use my time under the rig to give things a visual once over to make sure nothing is out of the ordinary.
Personally, I don't see either of these savings more than a few minutes of light labor. YMMV.
For those reasons, I'm out.
I use a Fumoto drain valve that makes oil changes a bit easier and minimizes the risk of damaging the oil pan threads. I haven't found a way to remove the filter without the removing the skid plate, though.
Can you confirm the oil filter can be installed from the side? I've looked a dozen times and by my eyeball assessment, it just didn't look like there would be enough room to get the filter in and out past the suspension bits. I did reach my arm down from the top and felt confident I could access it that way. Your genius bottom idea not answers my question of how I would avoid spilling oil everywhereYou go in from the side and if you have installed the filter you should be able to remove it by hand with a good grip. Photo from someone else showing the access.
And you can cut a 2 liter bottle or a past bottle like I did to catch the oil from the filter.
Yep, pretty sure the sway bar is the issue but I have yet to actually try with a filterI can install from the side, but I don't have swaybars![]()
Can you confirm the oil filter can be installed from the side? I've looked a dozen times and by my eyeball assessment, it just didn't look like there would be enough room to get the filter in and out past the suspension bits. I did reach my arm down from the top and felt confident I could access it that way. Your genius bottom idea not answers my question of how I would avoid spilling oil everywhere![]()
Thanks, and typing on a phone is the worst, I make typos all over, meant to say:.Yes without the factory skid plate and splash guard I can put the half cut pasta bottle in below the filter to catch every drop of oil as I remove the filter. I have sway bars still and no issue.
Just confirming this is the one to buy?
Amazon product ASIN B07D9DXCHP
Someone said there is a shorter nipple version but all I see is guys using this version on the 4.7
