Official ONSC member buying/selling thread (13 Viewers)
Looking for a car in the $5k range if anyone has something they are looking to part with. We gave an intern at the office that just graduated, and has no family to help figure things out. Shes spending $300 a month on Uber to get back in forth. Civic, altima, carolla, Something like that.
Best contact is 919-869-4seven3seven. Everything is OBO. In my way
Bilstein shocks
-TG5125 12” shocks with boots. One boot is torn, they have maybe 3-4 rides on them. $150
-14” shocks. The dust seals need seated back in. Other than them being dirty they’re in good condition. $100
12stateoffroad tube doors for 84-89 pickup/4runner. They’ve seen some a lot of abuse. The latches need replaced and the door bracket is bent but they still bolt up. $175
Sliders for a 84-89 4Runner and mini trucks, possibly other vehicles i can grab some measurements of the length if needed., 2x3 .120 boxed tube with 1.75 .120 tube. Dirty and a little rust and needs the slider mounts and tube cleaned off from my old exo cage. $150
ill have some more stuff posted up this weekend and some 80 stuff.
Puma PD-1006F 12v DC air compressor. Works great. $200. Located in Carthage, NC. Send me a text 541-609-eight 60 five. Code word: puma-pants.
This is an 80 that is going to be Grays first car. Turns 15 in March. It’s in pretty good shape for a 91 but needs a little love. Looking for a set of seats. Some miscellaneous plastic pieces and a drivers floor pan. If anyone is parting out an 80 or has some stuff laying around let me know. If I can’t find a floor pan I’ll build one out of sheet metal. Guy who had it used it to pull his boat and the floor is rusted out along the door jam. Eventually we’ll be doing sliders and a lift. Let me know whatcha got. TIA
I may have what you need in a couple of months. I also have some gray interior
Not mine, friend of a friend. He is a little crazy.
Thanks for the response not real particular about the color on interior parts. This will be his first car and will be wheeled. Mainly looking to make everything work and make it as safe as possible. I’ll probably put seat cover in it anyway.
Project for Sale $8,000 OBO
Not looking for trades.
I'm selling my 1992 Toyota Land Cruiser. I have owned it for 3 years now. It currently has approximately 213000 miles on it. It's runs and drives well, I routinely drove it to work and around town for years. Since I got it, I have replaced the radiator with a 3 row aluminum unit, put in a new AGM battery, LED headlights, and a rebuilt transfer case. It also has a new alternator, belts, radiator hoses and clamps. The front rotors have been turned and have new pads. As well as a new master cylinder The interior is great, with the exception of a cracked dash and some wear on the driver's seat. The tires are geolanders, with plenty of tread left on them. I also have the third row seats, original bumper, and original roof rack. Yes there is rust, most of it is surface rust. The worst is the driver's side rocker panel and up into the wheel well. See the attached pictures.
What needs work:
AC compressor works, but the system needs to be recharged.
Gas tank vent needs to be replaced.
Included in the sale will be the Prinsu roof rack that you see, the ARB bumper, and 12000lb Apex winch with synthetic line.
Please reach out of you have any questions or if you want more pictures.
What needs work:
Please reach out of you have any questions or if you want more pictures.View attachment 3543970
Located in Huntersville NC
40 series owners, here's what you need to update your steering. Howe Saginaw 700 series 3 bolt. Ports for hydro assist. Box it was in got wet so its looks aren't the best. Selling cheap because I've had it forever and am never going to use it. $500. Located in Carthage, NC. Send me a text 541-609-eight 60 five. Code word: Howe you doing.
Shop Clean Up - Miscellaneous fj80, mini truck, 4runner parts.
Everything is OBO, Pictures per request, Best contact is @4LowandSlow or 919-8six9-4seven3seven.
X4 sequoia wheels 17” $150
GX 6-lug rollers $50
3rd Gen 4runner/1st gen tacoma factory depo headlights, $50
FJ40 metal fan clutch shroud, $30
2x Eibach 1400.250.0100 springs $60
2x Eibach 1400.250.0150 springs $60
1st GEN 4RUNNER/PICKUP PARTS
1st gen 4runner top $100
1st Gen mini/4runner front axle shafts. (L&R) $50
1st Gen solid axle spindles ( pair) $20
x3 1st gen Rear NON IFS rear axle shafts $30
LROR custom T/C mount $30
22RE engine/transmission plate 5-speed $10
22re front timing cover with Oil Pump/Water Pump $20
22R Complete distributor w/ vacuum actuator $25
22re lower intake manifold with fuel rail $25
1st gen 4runner/pickup SR5 gray steering wheel $15
22re fan shroud, cracked at the bottom. $15
1st gen 4runner front plastic wheel liners with toyota mudflaps, $50
1st gen 4runner complete steering column assembly,(ignition switch, clockspring, switch assy) $50
1st gen 4runner heater core assembly with housing, $30
1st gen 4runner/pickup front headlight bezels (grey) one is cracked, $25
22re 1st gen 4runner airbox housing w/ MAF in good condition, $50
22re A/C bracket, $20
22re fan clutch with blade, $15
2x 1st gen 4runner gas tanks with sending units, $100 ea
80 PARTS
A442F 93-94 80 transmission factory new maybe 15k miles with aftermarket TC $500
A442F 93-94 80 transmission about 400K miles with stock TC $50
FZJ80 Steering box $150
FZJ80 stock springs, $5-
FZJ80 4” OME J springs, $200
4x FZJ80 Upper rear control arms, $15 ea
2x FZJ80 lower control arms, $20 ea
FZJ80 Factory transmission cross member w/ skid-plate. $50.99
Chinese FZJ80 Depe headlights with parking lights, $100
FZJ80 Brake pedal assembly, $50
2x 1FZ-FE fan clutch blades, $30 ea
FZJ80 power steering pencil cooler, $25
Factory FZJ80 VIP security system ECU
3fe vacuum switching valve assembly 135200-1440 $20
95-97 FZJ80 shifter bezel $50
95-97 Gray dash assembly with passenger side airbag $130
93-94 MAF (22250-66010) $100
FZJ80 complete distributor, $50
95-97 fzj80 center instrument cluster panel, $40
FZJ80 parking brake handle with cover, $30
1FZ-FE re-manufactured starter $75
1FZ-FE Denso Starter, $75
1FZ-FE Pair Valve assembly with tubes, $50
1FZ-FE Downpipes, Cats, Crossover frame 2-1 pipes, 93-94 $200
2x 1FZ-FE denso alternators, $50 ea
Homemade 1FZ-FE Harmonic balancer holder $27.53
80 PARTS
I will head over after work to take a look at your treasure pile.
80 PARTS
Eric, I'd love to have this little gem as a spare: 93-94 MAF (22250-66010) $100
Can you bring to M&G? If so, I'll bring $.
80 PARTS
I am interested in the headlights for the 80. What kind of shape and could I get a picture when you can?
Anyone interested in a 91 FJ80 ? Got like 160,000 miles. Not lifted but can easily be as I have the 2.5 springs it had under it still. New paint job to factory color. Like really new as of today. Paint is 9out of 10. Inside is 8 out of 10. Uploading pictures is painful here spead wise.
Anyway. It is a 91. It has 157,000 miles on it. I have not been into anything drive train wise since I have owned it. I have had it a few years now. I knew the previous owners too . I upgraded the 80 Amp alt to the 90 so you can still get them from Toyota. Redid the exhaust. Radiator. Fan clutch.
Thinking 13,000
That sound fair for a starting point price wise ?
