Official ONSC member buying/selling thread (16 Viewers)
so your saying I should do a H55 swap .....:hmm:
For that you're also going to need to borrow some 31's so your ride fits in Garage de Strange.
For that you're also going to need to borrow some 33's so your ride fits in Garage de Strange.
Dont forget the burnouts ;)
That ought to speed up your quest for boost :D
Quick calculation .... 33 not small enough. Edit to 31. :grinpimp:
Heres a long shot. Still doing some research but putting this out there early to see what may be available
Wanted: A343F transmission
non august-oct 97 build date
Preferred Serial number range-
97AE-07106 - 97H*-00001 or
97K*-99999 - end of production
Acceptable serial number range-
96JE-06161 And newer
@Roxx
@GLTHFJ60 --- did i just toss mike's 97 at the recycler?
I dont have one. However there are a couple of 97 at l&l salvage yard. Long shot but who knows
Looking for a 2f air cleaner...not the canister style version. I had one but ended up being too beat to use.
Will this one do
^^^ could work depending on underside condition and cost. Also, does anyone know if the wing nuts missing are fancy teq specific or just metric run of the mill?
Metric run of the mill AFAIK.
Yup, definitely did. That's a FJ60 air cleaner. Only thing that might not work @S4Cruiser is the carb height. IIRC the later 2F carbs (that came on a 60) are a little bit taller than the old carbs.
