Greetings all,
I have been lurking here for a while and have found answers to every 80-series issue I've encountered, until now... Short version:
I am building a custom exhaust for my 1993 FZJ80. I am switching to a single cat and would like to replace the two pre-cat O2 sensors with a single sensor (less money, fewer things to fail) and wire the single sensor to be read by both inputs. Does any one know if this is possible or does the OBD1 ECU require input from two separate sensors?
Long version: When I bought the truck I looked into fixing the CEL so I could try to get the truck into closed loop and save some fuel. When I read the codes it showed Throttle Position Sensor fault (fixed) and O2 sensor fault (still broken). Both O2 sensors were surrounded by so much rust I couldn't see where the stud, the nut, the flange, and the pipe began or ended and decided to leave it alone. A few months ago I heard an exhaust leak and took it to a muffler shop only to have them tell me they can't get parts and quoted me a(n unacceptable) price to fab something up. I figured I would live with it. Fast forward to now. This week I was pulling a trailer up a 7% grade and when the truck downshifted into second at WOT... BAMTHUD... my exhaust leak turned into an EXHAUST LEAK!! Turns out I had fired an O2 sensor out the side of the pipe. As such, the exhaust repair won't wait any longer. Additionally, over the winter I will be replacing the turbos on my car and will have two turbos (perfectly sized for a 4.5L engine w/ a 5000rpm redline) sitting around doing nothing, so, ya know... twin turbo Toyota come spring time (I'll start a separate thread for that). Any exhaust work I do now is lead work for that.
