Can I get a copy of the spreadsheet? gregsolis@hotmail.com
Anyone hosting it so we can get updated versions online?
"quote" Motor Mounts to Block Bolts from coolerman Post #105
12 12mm x 1.75 x 32mm. Split Washer. 17 mm head. 19mm will NOT fit!
bolts heads stamped with a 5.
in an earlier post it states motor mount (cast piece to block) 12mmx1.25x25
Does anyone know which is correct.
also it said engine splash guard to frame m10x1x16 qty 2 with captured split and flat.
This doesn't sound right, can anyone check please
I have the excel done now and you can filter by description, bolt size, pitch and length.
OK guys.. I have found the BEST PRICES EVER on metric / Hex Head / Grade 10.9 (YELLOW ZINC) Nuts and bolts, you will ever find.
The name of the Company is Cascade Nuts and Bolts and there right here in Salem OR... Phone number is 888-511-1005
Your Welcome![]()
Well here is the web site for this company but be damed if I can find anything on it!Weird interface to their parts... I'll figure it out ....
http://cascadenutandbolt.com/index.jsp?path=externalhome
I'm at work and not near my rig, so does anyone know the sizes of the bolts that are along the frame that holds the fuel and brake lines against the frame?
Also for the Bezel, nuts to secure the radiator mesh to the bib, the bolts that hold the heater fan, the rear heater, the seatbelt mounting bolts, instrument cluster screws, ashtray screws, fuel filler neck bolts, fuel tank strap bolts, rear heater bolts, pintle hitch bolts, knuckle wiper cover bolts
