I purchased a non ignition control TBI system through Howell Performance out of Michigan. Timing is controlled via vacuum from the Holley 670 cfm throttle body itself. I'm running an HEI distributor.
Since running this set up, I've had engine performance issues. I have a built 350 and the thing is weak beginning at 4,500 RPM. I'm running an RV cam, roller rockers and motor is bored 40 over. I have dual exhaust with rams horns.
Despite having the chip reprogrammed multiple times, I'm still having troubles at higher RPMs. I can't seem to figure this out. The truck drives well at lower RPMs and is a torque monster, but gives out at higher RPMs.
My local speed shop suggested that I change to ignition control because it could be directly related to timing at higher RPMs, as a non-ignition controlled TBI can have problems controlling timing at higher RPMs because lack of vacuum. I have about 10 inches of vacuum.
Does anyone have suggestions?
