Clutch woes
and how did the GM clutch disc fit with the 3finger clutch/stepped fly on the F? Or are you running the newer flywheel?
No problems, but if I remember correctly you need to shave about 1/8" off the GM disk as its just slightly a larger diameter than the Toyota.
Do you have to use a special pilot bearing with the sm465 to F engine. ? Are using the Toyota bellhousing ?I assume so. Isn’t the SM465 input shaft shorter than the Toyota input shaft. ? Just curious. I haven’t been into these types of conversions in awhile. Cheers.
I believe the pilot bearing is slightly longer than the Toyota.
Yes, 3 speed Toyota Bell Housing
Mine was a SM420, but I'm assuming the same length input shaft. A correct pilot bearing came with the kit I ordered from Advance Adapters.
