Where are you in the bay area? Maybe I should come over and help! I am on the coast south of half moon bay!
what ? they macth up exactly...maybe your not seeing the pictures correctly... soid white to positive and white/blue to negative - thats what i said - thats what the picture shows. move pastLook @ your post 69…your words in this post do NOT match your picture in your posts 112 & 113.
1st I would check the plug going to the ING switch. Then, is there power going to the ing switch, according to your wire diagram the White/blue wire would be supplying power to it. If the wire is hot to the switch then it is most likely the switch itself.
Sorry, yes you are correct. I was looking at your pic @ it appeared to me that you had that red cover on the white/blue wire. Took another look. Carry on.what ? they macth up exactly...maybe your not seeing the pictures correctly... soid white to positive and white/blue to negative - thats what i said - thats what the picture shows. move past
PLEASE use the solenoid terminal designations (30, 50, C, ign coil) to describe what you speak of.when i previously jumped the starter positive to the starter to ign coil stud - all the sudden i got volt readings at ign plug and at coil
???Obliviously, The coil got the 12 volts from your jumper wire which came from the big lead on the starter which is connected to the battery. When operating correctly Power should be come from the ing switch with the key in the start position, thru the blk/white wire to activate the starter solenoid. All power for the ignition system has to go thru the ing switch. When you turn the key to ON, it powers the other curcuits in the fuse box, and in turn powers the coil, then turn the key to start, which supplies power to the starter soleniod and the engine cranks. Your tests confirm the soleniod is working.
I don't understand this infatuation with the starter solenoid, when he doesn't have keyed power to fuse box. Which means no keyed power to the coil and most likely no start power from the start wire leading to the starter solenoid.???
I didn't see where Kyle turned the key to "on".
lF he jumped power to the solenoid 50 terminal, the solenoid is energized, and as long as the solenoid remains energized, the "to ign coil" will feed 12V positive directly to the + coil terminal. The feed is interupted when the solenoid is de-energized.
But I'm not certain what Kyle wrote in post 126.
@pb4ugo
Look, Kyle in post 125 is still hung up on what the solenoid and starter have to do with feeding power into the system.
Also in the post, he states, "when i jump the power to the ign coil output post - everything lights up...so my mind cant take me away from that.." We learned in his post 133 that he jumped from the battery cable connection on the solenoid to the "to ignition coil" on the solenoid, effectively bypassing the solenoid. BUT, by backfeeding power to the coil, it appears it must have backfed power to the "ON" circuit, if that's what "everything lights up". means.
@Kschep , just to be certain, what does "everything lights up" mean?
ok readings abound...
just to start it seems EVERYTHING stops at the starter solenoid output post - voltage going in = 12.18 ; voltage coming out (to ign coil) 0.00
but numbers wise voltage readings....from the beginning
-battery + reading after full charge according to my charger = 12.18 volts
-Battery - ground reading - same 12.18 volts (so good ground there)
-from Battery + to NEW fusible link - 12.18
-from battery ground to ampmeter - full 11.9 and 12-something readings (both on the neg post and positive post on ampmeter) - but depending on where i help it it gave full or little below (post vs actual ring connection to post)
-From battery to starter (with new Well grounded position on frame) 12.18
-*****from starter to ignition coil - 0.00 !!! ****
-Fuse Block - 8 fuse positions - 4 of 8 have 0.00 Volt reading - (with key-on position)
top 3 fuses - 8.5 volts, 8.5volts, 7.9-8.3volts. - depending on how the prong is touching the surface it wants to jump around (i should just
clip it)
Middle 4 fuses - All 0.00 volt readings
Last botom fuse (headlamp) - jumps between 6.3-7.2 volts (again depending on the prong and holding it against fuse clip
SOOOO, theres the numbers ..... I think it has everything to do with my Starter solenoid or starter as a whole.
NEXT - jump the starter post and see if engine will turn...be back with that answer shortly
Your "fuse block" response in the 1st quote I have referenced and your latest response are not consistent. If both are true, I would look for a bad ground. Inconsistent readings are typically grounding issues. If I recall there is a ground wire under the dash near the fuse block.so I put key in ignition and turned to "on" - when i do that the fuse box readings all go to 0 ... when i take the key out i get readings so that should tell us something too
