New F & 2F carbs (22 Viewers)
Okay cool. Thanks. Looks like I'll be putting the bread money away for a bit. Thanks
Received carb yesterday and installed today!! Looks good, runs good, pretty easy to swap!!! Thanks Marshall!!!!
Replaced a 38 Weber with the THC carb .So far it starts and runs great. Have not checked the fuel mileage yet. We used a SOR spacer and cable with the threaded end ( have to cut the barrel off) Bought a nut and olive from the Toyota dealer. Mr. Gasket 1486 air cleaner (6 1/2"x2") and universal choke cable from AutoZone. 3 1/16" x 5 1/8" air cleaner adapter from the local speed shop.Used 8mm x 60mm carb studs(Dorman 675-336) from O'Reilly's.
In Stock as of 11/14/2016
FJ60's
$270 shipped to the lower 48
If the button doesn't work try this link: Error - Cookies are turned off - PayPal
FJ40's & FJ55's mechanical linkage type (non throttle cable type) this is mainly for you 2f folks
Includes air cleaner spacer and choke cable stop.
$271 shipped to the lower 48
FJ40's & FJ55's with throttle cable type systems uses 1970-1973 FJ40 throttle cable. This carb can be used to retrofit those who have Weber or Holley carbs as well. If you have either of these carbs you will need a stock carb spacer.
Includes choke cable stop and stainless steel throttle cable bracket. You will need to purchase the throttle cable from SOR.com or Toyota ( SOR qty1 of part #042-04B-EC and qty2 of 042-34A)
$315 shipped to the lower 48
If the button doesn't work just use this link: Error - Cookies are turned off - PayPal
If you live somewhere besides the lower 48 I'll ship it just please PM or e-mail me for a freight quote.
Accepting paypal links above or directly to my paypal address marshall@828rugs.com or checks
Marshall Shepherd
500 Marsh Creek Dr.
Mauldin, SC 29662
Please note that checks will need to clear before I ship. Sorry for the delay.
New, brand new desmogged carb.
These are aftermarket carbs. I've been working on bringing these into the US for a year now. I have a product you will really like.
They also come with the high altitude jets (they reside behind the big bolts on the fuel bowl), the 9mm air cleaner spacer and the choke stop if needed.
The first carb below is the f carb with cable brackets. You will still need to supply your own cable.
2F with mechanical linkages both 40 & 60 series.
How can I contact you to discuss a replacement carb for my 1978 FJ40 with a 2F engine? It currently has a Holley remanufactured carb, and the base plate has been changed out by a mechanic. Is there a phone number I can call?
Drove the 40 up to 7,000' elevation yesterday. Runs perfect with the stock jets. Marshall, the dual reservoir master cylinder and 3 to 4 bolt adapter are from Mark's Off Road. Our 61 had a single reservoir with a 3 bolt pattern.
Marshall, just ordered an F with cable linkage. Thanks and I can't wait.
3,000 miles on my Trollhole 2F carb from a few months ago. Once I installed, I simply set it and added a new fuel filter and went. Knocks out 15mpg on my 283k 2F thats an original shortblock.
No issues and it starts quick every time. No random puffs of fuel at startup like my tired Aisin...
A very happy customer and Marshall has great customer service!
Did I make it? Ordered last friday?
I would like to place a carb order for a 1983 FJ60. Desmogged. Pls let me know.
Subscribed! I'm interested in a carb for a 1971 1F. It currently has a weber 34 with a cable, so I think I need the accelerator cable option as well. Should I wait until you have them in to place an order, or should I just order now to get in on the next batch?
Thanks, and looking forward to it!
Eric
Just placed my order with a cable set up for a '71 FJ40.
Thanks!!
Sent Payment for my 1983 60
Ordered Carb today (01/27/17) for 1974 FJ40, "F" engine with mechanical carb linkage. All smog and fuel return has been disabled. Thanks!
