Hello. I have a new battery drain after I thought I solved this problem I had to have the alternator rebuilt, solved it). It occurred after I installed the new headlights kit from Toyota. I took my first drive after the install. Stoped at a fly casting workshop for a few hours and when I went to leave it was dead as a stone. Got a jump and went home to ponder.
Forward to today. I have my 40 hooked up to a battery tender. and was able to poke around with a multimeter at the fuse box. The top 3 (tail, stop, and lighter) all show a draw of 13.16 volts with nothing on. There’s no voltage to the cigarette lighter, the horn works fine, but checking the turn signal relay it says it’s pulling 13.36 volts. Testing the system I had no right turn signal then spotty turn signals. I’m betting the relay has gon bad. But why is it drawing power when everything is off and why would the red and green wire be drawing power when nothing is on or connected to it? Is it a constant power wire?
I’m a little perplexed, any advice is appreciated.
