I tried starting it today with ether and it still cranked and cranked with a few more rumps, but never caught and started. Then, because I suspected it was a temperature issue with the fuel, I took a small propane torch and held it on the intake manifold for a few minutes, and then pumped the pedal a few times and tried to start it. It almost started! It didn't, but it was as close as it had come all day even with the ether. Perhaps ether in conjunction with warming the intake manifold would have done it, but by then I had nearly killed the battery, so I put it on the charger and let it rest.
That kind of verified (at least in my mind) the theory that the fuel wasn't vaporizing in large enough quantities to start the engine and I quit trying after that. Didn't want to burn through a bottle of propane just to prove it. Here in a couple of weeks it should warm back up to around 0F and I'll try again. I started it the other day at 5 degrees above 0F and it started albeit without cranking and complaining for a while.
