do a search for firefighting trucks or airplane towing pics, that looks pretty official. But surely there must be pics of UN vehicles out there in Africa, Middle East etc, no?
This mounting location is inherently weak compared to the real recovery points any large SUV comes with that are on the tips of the frames front and rear.
somewhere buried is a picture of a Toyota owners manual with detail on the pintle hook.
Does anyone actually have a manual or any real data from Toyota that the pintle mount is not legal or rated in the U.S. or that it is rated in other countries?
According to my U.S. 1993 FZJ80 Owner's manual, pg113, "Hitches":
"Use only a weight carrying hitch designed for the total trailer weight. Toyota does not recommend using a weight distribution (load equalizing) hitch."
I would say that a pintle hitch is a "weight carrying hitch"
"The hitch must be bolted securely to the vehicle frame and installed according to the hitch manufacturer's instructions."
I would say mine is "bolted securely to the vehicle frame and installed according to the hitch manufacturer's instructions"
NOTICE:
Do not use an axle mounting hitch as it may cause damage to the axle housing, wheel bearings, wheels and/or tires."
It does specify not to use this:
Or Axle mounted hitches that must be so bad that I can't seem to locate an image of them for cars or trucks. Just ATVs...
If pintles were so bad, they surely would have mentioned them.
Dave
For clarification, the pintle hook is not in fact attached to the frame. It is attached to a crossmember than connects the frames, and this is why it is not recommended in the US where SUV owners regularly tow campers the size an weight that are simply not seen elsewhere in the world.
When they say frame, it means the two longitudinal frames.
DougM
.....Of course the USA owners manual says not too......
If you plan on carrying any significant amount of weight, safely, you need to have a rigid class III hitch mounted directly to or into the frame.
no doubt, nobody argueing against thatIf you plan on carrying any significant amount of weight, safely, you need to have a rigid class III hitch mounted directly to or into the frame.![]()
... Toyota Japan approves 450kg, the military / UN uses it towing 750kg trailers ...
The pic I posted above shows the Toyota Pintle, we have a DixonBate wich can rotate. We use the VarioBlock System to use Pintle, tow-ball, winch or nothing to have space for the door to swing open..
@thisilldefend, pics would be great.![]()
I just quoted from the U.S. manual. It does say specifically not to use a weight distributing or axle mounted hitch. Nothing about pintle hooks. If it were a potential problem, they would have stated so.
You always hear "It's not legal here in the US", well, cite the literature. It's not true just because you read it on teh internets....
I want a Toyota engineer to tell us why "it is too weak". I want to see a statute that states that it is "not legal"
Dave
I'm interested in the VarioBlock system that you mention above. I can barely read "Rockinger" on the photos and have googled "Rockinger Varioblock" and also Vario Block but only find a few sites. One or two in French (which I don't read) and a couple in German (which I can read). Ich kann auch Deutsch sprechen.
Where did you find that?
