According to the member this is a picture from the owners manual.....
Great lead. I PM'd him about scanning specific information for us as it pertains to this thread.
Dave
I forgott)Soenke,
as requested.
What's with the red lamps on the tailgate? Rear fogs? Are those factory?
Dave
Paul, are you screwing into the tapped holes in the crossmember?
IIRCC the bolts are smaller than M12. The thread is fine also.
Thanks again Sönke. I finally found their corporate website and I was very impressed with the possibilities.
For anyone that cares, you basically mount the block (with optional protective cover) on your 80 which looks like the one in the photo in post #15. You then buy an attachment mating plate and bolt this to your whatever (Pintle hitch, etc.). There is a small lever on the block that pulls up and then you push the mating plate on at a 45 degree angle and twist it into place. Then close the lever to lock. This way you can keep your hitches inside and only bring them out to play (at a moment's notice and with no tools) when you need them!
I am going to do some further digging and will start a new thread but can anyone tell me if the center to center bolt holes are 83mm x 56mm or 85mm x 45mm? Also, can you verify that the holes are 11mm?
Right, just been out and the hole centres are 86mmx44mm. Same on the rear cross member of the 80 series.
Paul
Thanks for the effort Brett![]()
Thanks Paul. That isn't one of the Variobloc choices but I guess it's close enough to 85mm x 45mm. Not sure about the 11mm vs. 12mm holes. I'll have to look at their website again. The holes in the Variobloc base plate aren't threaded but you still can't shove a M12 X 1.25 through an 11mm hole!
