It only took me 10 months but I finally repaired the rear window defroster cracks.Pulled the tint off the hatch glass yesterday.
It looked nice a black from the outside but from the inside it was streaky and hazy. There were 2 layers of tint on there. Jeez that was time consuming and tedious.
It will get replaced with a light UV film at some point.
Still have the cargo and 2nd row glass to remove. Figured I'd start with the toughest most time consuming window.
Noticed a break in the defroster tab ground tab on the passenger side. View attachment 3624355View attachment 3624363
Wondering if this can be soldered back together with a low voltage solder gun or bridged with a small wire
Has anyone tried this type of repair?
My floor liners that I got from eBay arrived the other day. I got around to installing them today. They fit pretty good except for the rear heater on the second row. It's clearly for a FJ62 or a FJ60 without the rear heater installed. Once I trim the 2nd row mat and they have some time to settle they should fit much better.
That’s exactly what I used and it works ok. About as ok as the original heater traces, which is to say: not great.It only took me 10 months but I finally repaired the rear window defroster cracks.
I used MG Chemical Silver Conductive Pen & tested it with the Ohm meter for continuity. All appears good.
Will have to wait for a frosty morning to see if it will actually hold any current and actually work.
View attachment 3838724View attachment 3838725View attachment 3838726
Ugh, I guess anything is better than nothing. I'll test the voltage back there tomorrow and see what it's showing. If it's too low I may run another 12 volt wire back there and use the current wire to trigger a relayThat’s exactly what I used and it works ok. About as ok as the original heater traces, which is to say: not great.
These look great!My floor liners that I got from eBay arrived the other day. I got around to installing them today. They fit pretty good except for the rear heater on the second row. It's clearly for a FJ62 or a FJ60 without the rear heater installed. Once I trim the 2nd row mat and they have some time to settle they should fit much better.
I might need to add a floor mat anchor on the driver side as it seems to move just a bit. I have some spare black Toyota Toyota/Lexus anchors and a grommet kit that will fix it right up.
View attachment 3838731View attachment 3838732View attachment 3838733View attachment 3838734View attachment 3838735
These look great!
Are these rubbery or more of a hard plastic? How thick are they?
