This thread is to detail the build of my front axle for a 1978 FJ40 using mostly toyota parts. Intended purpose is to do some medium duty offroading with friends but also to retain road manners and be able to take my kids exploring in the woods. Mostly I enjoy a challenge and the time spent during the build.
To get this far I've spent lots of time reading threads and have collected the following parts for the build:
1. FJ62 front housing because it is setup for 9.5" and has factory stiffener on the underside of the housing.
2. 80 Series 9.5" E-Locker third member re-geared with 4.88 nitro gears.
3. Donor 80 series front axle for brakes and many small parts.
4. Hellfire knuckles with 20mm trunnion bearing as this is not the rev 2 version.
5. RuffStuff diff cover (1/4" thick fabricated).
6. Pneumatic cylinder to replace actuator.
7. Warn locking hubs (but I have some aisin on another spare axle that I may use instead).
8. Wheel spacers/adapters 2" thick, which convert to 8x6.5" to fit the oem HMMWV 12 bolt dual bead lock DOT approved wheels/tires.
9. 80 series front axle rebuild kit.
10. Still Need: custom inner axle(s).
Current status is that the 80 knuckle balls are welded to the 62 housing, however I don't know the WMS or caster/diff angle yet and may have to adjust. I bought this already welded. Welded cover has been removed to fit the ruff stuff housing.
4.88 gears have been installed in the third member.
Donor 80 front axle parts disassembled.
Time to start the real work.
