Just being curious I put the 80 on a weighbridge, it is verified for industrial use so should be fairly accurate, and for the princely sum of €1.00 or $1.14 to you guys across the pond cheap enough.
I weighed whole vehicle, and then the front axle and rear, then filled with diesel, I could use the additional fuel (75 litres), to verify bridge accuracy, I then weighed her again.
So, for future reference my HDJ80 weighs 2,420kg.
That is:
Brimmed fuel tank, oil, screen wash, coolant plus about 28 litres of shower water in the right rear wing, all eight seats fitted, two small tool rolls......oh and my Cookie the ' I will rip you limb from limb' little dogs additional 10kg.
This is how the car is generally used, I will in the next 9 days load up my full off road kit, so thats three seats out, and then the usual drawer unit, fridge, wardrobe, you know the score, the roof rack will also go on as well with RTT, awning, sand ladders, 60" hi lift, 40 litres of diesel, and a second spare wheel.
I will update the loaded figures as soon as she is loaded. Later in September there are a couple of small units to be built inside, I can weigh these individually and will add accordingly.
None of this is a pointless exercise, I will be changing the suspension next year, using this data I should be able to get the springs right first time...............mental crossing of fingers.
Regards
Dave
