My FJ60 Project
I didn't see it mentioned, but did you do a rattle can paint job or the real deal? I seriously need to do the same with my windscreen seal and gutter seals. It's pissing down rain here ATM so it won't happen for a few weeks at the earliest....
How is the road noise without carpet? It looks super clean.
I have not a past experience to compare with. The carpet was the very first thing I removed from the truck as soon as I got it. It was filthy and teared bad.
Anyway, the cruiser have no A/C, so windows ride down most of the time.
I went with the real deal. Used PPG Urethane 2K (no clear coat needed) Freeborn Red. Just painted the roof and rain gutters though. Every time I wheel the truck, new scratches and dents appear, so no more paint jobs for now.
Its been a while since I posted the last updates.
So its time for a new update...
Several months ago I found this FJ62...
... a few days after the discovery, look what followed me home...
After several filthy days, everything was disassembled and cleaned.
The 4:11 thirds were reshaped and new OEM pinion seals were installed.
Spartan Locker installed in the rear third.
Thirds installed.
New U-Joints.
Knucle and rear axle rebuild (seals and bearings).
Rock-Ring Knucle Felt Protectors. Really beefy protectors...
Marlin Crawler Inner Seals.
My alternator bearing had a strange sound lately, so I decided it was time for a new one.
Went with a Mean Green Alt.
Also bypassed the link fuses with a new cable and 250amp mega fuse in a BlueSea fuse box.
The day I was installing the MG Alt, my 3y/o kid managed to let it fall from a 6ft stair... :mad: The alt fan suffered the most.
So I went to my local alt shop and got this $5 metal type fan. I have not noticed this before, but this alternator turns REALLY HOT with use.
Is this normal for a 200amp alternator?
Should I have to use the plastic type fan?
I used the wagon for a day trip to the beach and the alt runs flawless. The OEM volt gauge marks somewhat over 14V even at idle.
One more thing about the MG Alternator: IT IS NOT A DROP IN! I needed a new belt 1" longer and the new battery cable is a MUST.
Also installed a new-to-me radiator fan shroud.
Assuming the alternator is functioning properly, the heat on it would be a reflection of power draw. Maybe double check the voltage regulator is installed correctly, but after the vehicle is warmed up and the batteries are topped up, it should actually make less heat than a lower amperage unit.
Otherwise you may have an excuse to throw some venting in the hood if your looking for something else to do.
we need to ride soon in PR...we have a Safari in Yauco this sunday..
i saw a Ham base ant...im KP4CHE most of the time in 145.470
Indeed!
WP4ONZ here, but Im a newbe at ham radio. I got my tech licence 2 months ago and have not taked at all... Just scan and listen.
I will assist to a 24hrs emergency communication drill in June 23th and probably to the Caguas ride the next day.
TacDoc that is one great looking rig, nice mods, great craftsmanship on the homebuilt\custom pieces. Got a question for you that I didn't see answered in the thread. Did you end up getting the headliner down to look at the rust from the underside of the roof\front windshield edge? If so, how does the headliner come down?
Its like a surgery. You have to CAREFULLY peel it apart without tearing. I removed just a small pocket enough to use a small brush and apply some rust treatment. Looked carefully using a white light and it did not look that bad. Just some superficial rust. Dirt just blowed away using compressed air. There is some kind of "crossmember" just where the outer body was rusted, so there is not much I could do from the inside.
If I ever have to repair rust again, I'll weld a patch and probably will have to look for a replacement as I doubt the headliner will resist removal without tearing it nor the weld job heat.
Glued it back using UHU cement.
Want to share pics from my last weekend trip to Corredor Ecologico del Noreste and La Selva Beach.
Northeast Ecological Corridor is a protected Natural Reserve in PR. La Selva is how locals call this beautiful beach. In the winter we have world class surf here and in the northwest part of the Island as well.
Enjoy!
This is the entrance Lat 18°21'19.99"N / Long 65°41'53.72"W (D@mn politics!)
Plenty of vegetation... and a few more nicks and scratches to the truck's body and paint... more character to the 60!
Panoramic views
There is a small playground at the top of a mountain
He is the one having the most fun…
La Selva Beach
There are some crawling routes (4Lo) but the official photographer (AKA the wife) wanted to go inside the truck. She did not want to miss the fun…
Next time I’ll have some more action pics.
In my opinion, you have got the greatest FJ60 on this entire sight. Well done on this excellent write up, and I cannot wait for more action shots!!
I'm sure I've said this before in this thread. But damn that thing is clean.
How do you like the 4.11's?
