Those look great! Look forward to hearing your experience with them. I don’t want to start a debate here, but what tire pressure are you running? I’m sure you’ll experiment with it as you rack up the miles.
I have always liked the 255/85's on vehicles with narrow wheel widths. They give vehicles a much more traditional look while providing modern tire features over like a traditional 7.50X16 type tire. The fact that they are a true 33 makes them even better. They fill the wheel arches up much more properly on a 60 series. I thought about doing this when I lifted mine but did not have the scratch to pull off new wheels as well as tires. The extra cost of the 255's over 33X10.50 forced me to stick with the 15 inch setup on mine. I also was worried the 255 size would be hard to find if I blew out a tire while travelling. Seemed the places I priced them always had to special order this size. But seeing this on your truck may motivate me to switch. Looks great.
Those looks damn nice on that truck. Looks like you got 5 of them.
I think you’ll be fine with road debris etc, tough tire. Lots of house rebuild construction in my area and I’ve had a few screws in my Nitto Ridges with no leaks or repairs yet, lucky maybe.
Keep those rotated often, I made the mistake of not doing so with my Nittos.
Those look totally awesome. Perfect proportions
If your rebuilding your gearbox drill and tap it for hydro assist. You can plug the ports until you decide to use them. My SOA 60 has it and drives like a dream.Life has me on the run. So while I'm busy with work the steering box is going for a rebuild.
I hope its not too worn out. If it is, I'll source an 80 series box and rebuild that.
A slight step back. My TRE that connects the steering box and damper was falling apart. If I had to point a finger, it would be at the really worn out box having so much play in all directions. I felt an internal clunk, but really it was also exaggerating the fact that the mini ball joint on the TRE was worn.
20,000 miles on a 555 part and its dead. @orangefj45 for the save....sending me the parts to fix this and I'm going to try a 4* caster shim up front to see if I can finally put the front end of this race tractor to bed. A TRE inspection is now going to be a part of my oil change routine with chassis lubrication.
Thanks for the call and order Alex!!!!
FWIW, we've sold and installed literally 100s of the %%% TRE kits, as I'm sure Kurt has as well, and we've been very happy with the quality and reliability!
Georg
Valley Hybrids
Probably tough to quantify given the combined work done but how much improvement do you think the caster shims created?
I’ve been threatening for a really long time to put in some 2-4 deg caster shims. Your comment also reminds me not to trim my new u bolts until shims are in.
