Thanks. I bought those box plates that others were talking about on a few threads. They go more toward the back from about this place.Somebody sells plates to box the area forward of that in. Might be a good idea to do that after fixing the back section.
I still think that has to be pulled all the way apart
Those dunlops hiding under the table will outlive most peopleThe suction tube assembly is ok. The place that said they had it didn’t. I didn’t think they did, but you don’t catch a fish if you don’t put a line in the water.
Bit more cleaning and good to go
And
Is the frame sitting square?
If you can install a piece of tube (purple) in both of the shackle hangers, do they deviate from horizontal the same amount?
If you can install something akin to a bolt in the rear spring pin hangers, and shackle hangers, you can get an important (green) dimension. Anything out of 'square' will reflect on the hypotenuse of the (green) triangle, like if the passenger side rail is bent up and slightly twisted from the point of the frame crack.
Happy how this is coming together.
Thanks but the real credit is to Rus @solomrus and his craft not mine.I am impressed by the level of “research, and trial” that you have put into this. Not that most of wouldn’t but I never would have thought about a frame requiring the level of detail… I know it demands it as it is the foundation of the entire truck. In the hands of lesser skilled people, you’d always wonder what your level of perfection is.
I was discussing something similar with @zerotreedelta about the levels of performance the engine is capable of…not meaning getup and go but, performance like a highly trained athlete whose muscle, breathing and brain are all synced up perfectly.
Looking forward to each post @OlYellr.
