Build My first '40 and the venture
Get it B!
Cut the driver side to do prevention-
Yellr took a dump on the floor after cleaning behind the plate. Mind you, cleaned before and shop vacuumed too before.
So after cleaning etc, exposed this gem hiding behind where the inner channel was removed and cleaned
Put a light on it inside frame. Image from below…. Frick.
Dang, glad you found the cheese so you can repair. Tank is looking great, I need to do something about mine I think. Looked fine when I pulled the sender but should probably throw a probe in there or drain for the real story.
Yellr's going to be tight!
@RevISK and I were on the phone discussing eigenvalues, gusset angles a couple days ago… said the gussets looked vertical. They angle back about 12 degrees.
Anyway… driver side outer gusset on to add more lateral strength
Here is how the cheese wiz patch came out
From the bottom
Eigenvalues…
Tacks look good B. and Run lays a mean bead on that gusset. I need to get on his list for those.
Makes me want to go weld something.
Back to trans swap prep.
@solomrus would you be willing to sell these plates by themselves?
We absolutely would be.
Hit me up via DM and we'll see if we can get you sorted out. 8^)
--r
