Well a bit of an update - Drove Yellr - first time since before Xmas.
In the next couple of week will be taking the doors off. The windows don't crank right (new regulator in driver) so hard - snapped part of the window crank off. Anyway - noticed the door bows in causing the outside door handle bolts to interfere with the window regulator. So want to get that right and replace the weather stripping while in there.
Getting parts ordered for some weekend fun come April/May. There is a chance I will take Yellr on a vacation in June if it goes just right. Will see.
And took Yellr in today to have it dyno'd - I wanted to know and have a baseline if anything done to it has an impact (all new bearings for example). Lets say I learned a lot. Mainly the spec you see (200 ft-lb torque and 125 hp) is an engine on a stand. Not all the losses between the engine and the tire. They guy doing the testing said 20-25% loss isn't unheard of and with the size of my tires (33) - he said probably more on the 25% side. And he said, every car is different so just a swag.
Also I learned, and maybe just this place, they test in 3rd gear - 4th is 1:1. I did ask them to conduct one in 4th so I know what RPM 70 mph is (max I would ever do on the highway). Photo at end shows 4th gear test. Movie is 3rd gear test + 4th gear test for rpm @ 70 mph...
Spec - max torque about 209 ft-lb @ 1800 RPM: 125 HP @ 3500 RPM
Take 25% off - 157 ft-lb and 93.7 HP
Take 20% off - 167 ft-lb and 100 HP
My results - 167 ft-lbs @ 1827 RPM and 91 HP at 3987 RPM
70 MPH in 4th gear = 2862 RPM (and my meter is 10 mph off vs reality which I suspected/knew)
Video
