Milo, maybe you're getting worldspan and Flentge pics mixed together?
No worries Milo....Thanks for the reply Jim. Am i supplying correctly the primary adv on my diaphragm to the carb with the other nipple capped?
Looks as right as it can be with the chinese carb.
I'll take your advice and see what happens.If the truck is desmogged correctly, the evap system works the way it's supposed to work.
If the desmog is hacked, then the only thing to do is "do no more harm". By venting the tank to atmosphere through the canister, the filter function for air in/out of the tank is maintained. Dumping to atmospere prevents pressure/vacuum buildup in the tank w/ the associated problems.
Looks as right as it can be with the quality chinese carb.
Indeed you did...without hesitation i might add. Thanks MarshallFixed it for you.![]()
Nope. But your close. There are 3 or 4 manufacturers that make the carb. Only one does it right.
