lovetoski said:Got mine finished. Took awhile to pull all the parts together. Prolly wouldn't have attempted it w/out this thread, and the increadible info provided.
Misc notes:
I had 3 loose manifold bolts
I ditched the HAI after im'ing with Mark W who said they often run w/out them in AK and no apparent issues.
The heat shield broke on dissambly (guess I rushed it), but JB weld to the rescue and good so far.
I have had an issue with fuel smell/tank pressure on hot days, and after trying everything recommended, I went to a GM replacement canister (it was super cheap, so no biggie if it didn't work). It appears to work, but like most things I suppose time will tell. Here's the thread from the 80's forum:
https://forum.ih8mud.com/80-series-tech/412261-charcoal-canister-great-option.html
I had help & parts from:
Torfab – loaner dizzy, carb adj, once-over on the desmog, more to come...
Jimc – recurved dizzy and misc desmog parts
Trollhole - carb
SOR – carb cap
Cruiserparts – airfilter housing
MUD
Here's a quickie video of the test run a few days ago in the Cle Elum vally (Van Epps trail):
Van Epps sept 2011 - YouTube
Doug...where are you getting the non-US air box/components?
I really want that setup but am having an awful time with the parts....
Thanks and nice job on the desmog.
It took 3+ months to track down the parts. I got the "carb cap" from SOR. That's the metal part that goes directly on top of the carb. As far as I can tell, this is the key piece, w/out it you can't do the non-US air box mod. They told me it was the last one they had...but that was a couple of months ago.
The round air cleaner was pieced together. The bottom was from an HJ60. I got it from cruiserparts. I cleaned it up a bit, repainted mostly. The top I also got from them...it was a new toyota part. I don't have the part number on hand. Sorry...but I'd guess it might have also come from an HJ60. I assume (assumptions can get you into trouble...) that the round bottom from a FJ62 could work also.
The rubber hose...well that's my original intake hose, but I just shortened it to fit.
HTH.
Misc notes:
Trollhole - carb
SOR – carb cap
MUD
. I am getting ready to put the engine and everything back together and would love to do this mod at the same time.
Also, if there's a better hose (part #) to use between the carb cap and the air cleaner housing, please let me know.
Parts from worldwide EPC- air cleaner lid, corugated rubber hose, carb connector:
17705 CAP SUB-ASSY, AIR CLEANER
17705‑68020 CYCLONE 1 $221.41
17881 HOSE, AIR CLEANER, NO.1
17881‑61050 OIL BATH OR CYCLONE 1 $195.12
17805 CONNECTOR SUB-ASSY, INTAKE AIR
17805‑61010 OIL BATH OR CYCLONE 1 $310.60
Yes, it seems like the metal parts would never need replacing, so would quickly go to class F status.
