Thanks Jim
Decided to purchase my early model Saginaw PS pump and start the mod on the stock bracket. With all the HA stuff I don't want to use the stock pump only to have it fail plus I gain the better flow rates of the Saginaw unit. Got a rebuilt from CarQuest from a 77' Chevy truck. Toyota high pressure line hooks as should
Stole the idea from RayN and made bracket for front may weld a tab on rear to use one of the stock sag bolt holes. Got my Tom Woods front DS
Also have a HD relay rod on it's way so I can complete the front steering.
Sent Tom my companion flanges and he drilled to match new flanges, all I have to do is slide up into place and bolt
Thanks Tom
If still no go I will remove the rear mounting ear this will allow the room.
Also the galv long bolts are only to hang the pump for fit check
Had some design issues to work thru with the Saginaw PS pump but prevailed and happy with the outcome
Very nice piece! Well worth the $. Allows for fine adjustment in stroke and is VERY strong. The clamp combined with Dave's HD tie rod no way bending will be an issue. Also happy with HA ram angles and clearances, nice OEM look
Enjoy the pics, time for a
