- Thread starter
- #281
PS Fittings & Cooler
Today some small parts showed up and got them in.
Installed 16mm & 17mm x #6 JIC fittings on the Sag pump and steering gear. Also installed the heat sink cooler where I thought it would fit nicely
This cooler besides cooling the ps fluid also adds 1+ qts of fluid to the system. This way I don't have to run additional sumps. Bout the only thing I lost was the fluid reservoir for the headlight eyewash, oh well. Waiting on the rest of the JIC, SAE fittings and hoses.
Anyway, got a box of parts and gaskets to take apart my front axel again to install the 3rds.
First, when you start filling the system go veeeeery sloooooooow! If you don't and the air purges you get to spend the next hour cleaning all the ATF off everything, so I get to say the proverbial "ask me how I know"
It did purge a clear itself quickly. I would say I had clear fluid running in less than 30 minutes, even the ATF in the reservoir
Also got the recurved dizzy in and engine running. Thanks again Jim
I'm in the process of ordering OEM 4.11 Toy R&P for the rear end and will set up the rear diff myself. Setting up a diff is about the only uncharted territory for me so figure might as well, got the tools got the talent, got the info
Had to get gas and charge the battery! Steering very positive almost twitchy at low speeds but ok. Suspension stiff yet very pliable! No high speed runs yet, just taking slow to make sure all systems are a go.
