Ordered the balance of hydraulic fittings and cooler from Service Center and PSC for my HA ram. Talked to Cruiser Dan and ordered rear DS hardware and pinion nuts for the output flanges at the front end. Now I'm looking for a pulley to use on the Saginaw PS unit. Really would like a wide belt pulley from a Volvo but having trouble in my neck of the woods.
Tomorrow will go get he pulley for Sag pump. After that I'm kinda in a holding pattern until the remainder of the parts get here
I want to do 4:11 R&P and lockers but will wait until my "program manager" provides funding
I know this should not be
even without the flange on
There is not that much use on that front R&P considering it's age so not sure why it's going
slip in the 3rd and call it good for now and slowly rebuild the 3rd's I have THEN do the whole thing, R&P & lockers and re-install the 3rd's AGAIN down the road. Well going to make some calls today, see what rebuilt 3rd's cost me or do it myself? Keep you all posted..... After prepping the pinion output flange for the front axel DS, I noted that the pinion output has play side to side and a little front to backI know this should not be
Installed some of the small parts after painting standard semi-blackFinal adjustment of pulley of Sag pump and is ready to run, just need all the little fittings from Surplus Center and PSC. Also noted one thing that is a little disturbing at this point
Now I have to make $$$ decisions. I have a good 3rd from another set of 60 axels I've been sitting on (3:73's). So now in order to get my rig up and running soon I have to tear the front end down AGAIN, just did it about 6mos ago
