- Joined
- Sep 26, 2005
- Threads
- 38
- Messages
- 1,824
- Location
- Port Orchard, WA
- Website
- www.projektenterprises.com
Sweet Rig
Looks great LT.
Is your cruiser coming to moab this year? I recall you have a bone to pick with coyote![]()
Looks great!
You can remove that top leaf no your springpack if you want to lower the rear a bit..
Ummm that would require all new links and an additional 3" of wheel base. Plus my links are mounted directly below where the springs sits on the axle.
I'm sure I forgot a whole bunch of other stuff. My cruiser still needs a lot of work left on it.
1.) Limiting strap
2.) Bump stops
3.) Shock hoop bracing
Absolutely no binding. Its a 1" bolt threaded into the main shaft. So the link can go a full 360* if it so desired and then some. Another added benefit is that the links length and shorten during articulation compensating for oversteer![]()
Negative. They are right hand only. On travel tho as the link droops down the joint will twist out and on compression it will twist in. That is what helps with it being an active link. Another thing to mention is that is a 1" x 8tpi so every half turn it lengthens a 1/16" of an inch.
