My original side and rear reflectors are pretty much toast at this point. The backs of mine are atrocious and are completely rusted out. The fronts look ok but definitely not perfect. Although I plan on restoring another original set, I wanted to see if I could somehow make a darn near perfect replica. Here is how I made these using Grote #40192. Grote's are nice because the holes line up perfectly on my rig and the round housing the reflector sits in is identical to OEM. I should also mention they are $3 each!
Unfortunately the stock red reflector is a tad more dome shaped than the Grote but I am searching for a solution to remedy this as well. I will keep an eye out. Anyhow, here is how I modified the Grote reflector to match my OEM one.
1. Here is the reflector and some of the tools I used..
2. The round part of the reflector backing sits a tad higher that the flanges. I used the pastic side of this hammer to tap the edges further into the housing and then tapped on the middle. This made the entire back flush against the cruiser. Here is a before picture for reference...
3. After that I lined up my old reflector with the new one. You can see the Grote flanges are round and stick out considerably than my old one. This is good because I used a scribe to etch the pieces I needed to remove and then began shaping to match the OEM one.
4. Once I have everything marked. I placed the reflector in a vice (protected it from scratches of course) and then began to file the flanges down to my scribe markings. Each corner will have two sharp points that need to be rounded slightly. For the record, I chose not to take tin snips to the corners because I didnt want to warp the corners. Filing took me a few minutes but it came out great.
Cont'd....
Cont'd....
