Making a fiberglass snorkel. (11 Viewers)
Iceland
Some of you may have seen this tread, there I was wondering about making my own snorkel from fiberglass.
I decided to make a new thread only about that fiberglass experimental snorkel.
So this is how it goes.
I started by masking off the parts of the car where the snorkel touches it, both the fender and on the top. First I waxed the area but I did not polish the wax off, then I laid a painters tape over the wax and then plastic tape over the painters tape. Fiberglass does not stick to the plastic tape.
Then I laid two layers of fiberglass over the taped area to make a base for the rest to stick to. This way it is also sure that the fiberglass piece will fit the car perfectly. I lifted the glass on the top about an inch from the top in the back, the reason I did that is so that water on the top does not flow inside the snorkel when braking or going downhill. The snorkel will suck air in from the back. I haven´t designed that part yet.
When these two parts were hard I padded the a-pillar with an old camping mattress and tape and joined the two parts together with glass. I used the mattress to lift the glass from the pillar because I want to allow water to escape the windshield.
To make the tube up the a-pillar I used some foam tubes I found in the hardwarestore, I taped them together and made sure that the tube is wide enough to allow enough air flow. These tubes I taped onto the base and glassed over them.
Then I used polyurithane expansion foam to cover the top and the bottom pieces. When that dried I formed that to the shape I wanted and classed over it.
When all of that had hardened I "broke" that thing off the car. With that off the car I could glass the parts of it I could not glass on the car.
Now I had a rough shaped fiberglass chunk to work with.
Now I used a fiberglass bodyfiller to smooth out the most obvious low spots and then sanded all down with a handheld belt sander. And glassed two layers over that. Then I had much smoother and better looking "thing" and when I had the edges cleaned and sanded down I started to look like a snorkel again.
Now I decided to test fit it on the car and see how it looked.
I´m going to cut it where the black line is and redo it to look better.
It does block the view a bit but I don´t think that it will matter.
This is how it looks right now. Now it is time for me to decide if I will keep on working on it or throw it in the garbage. The next step is to cut it open and remove all the stuffing and then drill all the holes to the fender.
What do you guys think about it... how do you like the design?
I´m thinking If I should cut the top open and make it again a bit lower, It will decrease the airflow a bit but it will might look better.
That was fast! From this angle it looks like you might want to flatten the part that goes up the pillar a little, Although I'm not sure how wide it needs to be to get proper airflow. Do you have any pics from the side?
A lot of work time and effort for something that appears to mimic the JDM snorkel I have sitting in my garage to on ;-)
I like it. Looking forward to seeing more progress.
That's AWESOME!
Haffi-
That Snorkel is AWESOME!! What's even better is that YOU made it yourself!!
I learned a lot just watching your thread. Thanks.
DONT toss it! If you dont end up using it I'd take it:D
Wow, nice work...
It looks somewhat..organic...for the lines of this brutish 80. But hey, what do i know anyway :D
Thanks.
I´m not sure when I will find more time to work on it but I will post updates when I do.
I was not quite sure that I liked the look of it but after looking at the pics I like it better and better. I´m sure that with small modifications I will be happy with it.
Haffi,
Impressive work as always :) ... With a little more work on details you can have a great product that could perform even better than the OE one ;)... Keep up the good work and the posts...
I just want to drag your attention to some potential materials that could enhance this product even further:
Think: GRP, Glass-reinforced plastic.
UV resistance additives.
Solid or even rubberized Gelcoat surfaces...
Carbon and kevlar ( especially Kevlar in your case ) are very good friends to the FG...
Good luck :)
:cheers:
Haffi,
Good luck :)
:cheers:
Thanks. I haven´t really thought about going into production. But I might think about making a mold when it is ready and I have tried it for some time. I will see if many people here will ask me about it and show interest in getting one for themselves.
I will keep on working on it till I´m happy with the look.
If I make a mold I will of course try to to that properly and then use gelcoat for the pieces I make. Fiberglass seems to last very well here in Iceland. We have been using it for fender flares for many years and the often seem to be the last thing standing when the rigs rot away from rust.
Looks awesome, how are you going to hollow it out for the tube??
Cut it in two, scrape it out add some layers of glass on the inside for added strength and then glass the two halves together again. While in two I will also drill holes, add nuts for fasteners and finally add the pipe through the fender.
I also want to use the fender part as a water trap, I´m going to position the big hole for air as high as possible and then a smaller hole underneath. Then I will add a hose and a valve for letting water out. I´m thinking that since water is heavier than air it will get trapped there instead of going into the air intake. I think it is impossible to make a snorkel that does not collect some water (suck in some raindrops and snow).
Time for a little update on this build.
I spent some time on this this weekend. First I cut of the part of the top that I did not like and filled the cutoff with expansion foam. Then I shaped that and glassed over and test fitted the snorkel on the car to see the new look. Now It looks much better in my opinion.
This is not the final look, the part where it lifts off the top is going to be a bit smoother. I will work on that with the final layers on the outside.
Since I was happy with the look I glassed that new part as smooth as I could. I also made a mold of the air intake with some mdf pieces and glassed that. I really forgot to snap pics of that.
With that in place I cut the snorkel open and removed the filling. Spent some time scraping, sanding and using a air dremel to make it as smooth as possible on the inside before glassing on the inside, one layer over all and two to three layers where it was thin and I had holes.
One pic in the end of the top section that I will glass back in place, I still have to sand it a bit better on the inside to get it smoother.
Next step is to fit it on the car, drill holes, add some fasteners and pipes and then glass them all stuck.
Looks like great work. Just wondering how much money you have in materials so far?
Also, I have an idea that may help you or the next guy trying this type of molding. You can use expanded polystyrene foam (EPS) to make the mold "core". You can get lots of basic shapes from hobby shops. This material can be glued with hot glue sticks and can also be shaped with coarse sand paper. The best thing is that when you have completed the glassing over, the EPS will simply dissolve away with common fingernail polish remover.
VERY COOL!
I like it because it reminds me of this...
Yeah, I was just thinking that the snorkel looked like some weird alien being had inhabited Haffi's 80...
Now I know that Haffi's 80 being underneath is sure better looking than alien-dude.:eek:
BTW, I do like the snorkel's design.:cheers:
Haffi
I kinda thought your air intake should hv the same visual impact as this :eek: :D
Thanks I have heard about that method but had just forgot it ;) It might have saved some time but how can you be sure that everything has cleared out and what would the inside walls of the pipe look like? Would they be smooth or coarse? I guess that the smoother the better for the airflow.
I guess that the materials I have used right now is close to 215$. I have used close to 5 liters of resin and 2 square meters of fiberglass mat then some paint brushes, tape, sand paper and these foam tubes seen on the pics. I also have bought one can of body filler. I have no idea how many hours have gone into the project.
