Machining a Groove out of a Companion Flange
Annapolis, Maryland
Is it worth trying to get this out, or do most everyone replace with new?
Not worth it when new are <$60
Even I am not that cheap. I would replace it but I would use a speedi seal rather than machine it if the flange wasn’t available.
Valley Hybrids or Cruiser outfitters could probably advise you/provide you with the right part. Obviously It depends on course verses fine spline and the correct bolt pattern. For example, personally if I re- gear my stock 71 course spline diffs I will be looking for a fine spline but with the older smaller driveshaft size/pattern.
