I've never used the coil wire to test for spark, but you don't want to hold it so far away if you do that. Only about 1/4 of an inch from some clean metal.hey. thanks.
so learning here and again thanks to all for feeding me good info. i found the FAQ.
for testing spark i can
1. squirt starter fluid into intake and crank it (no extra hands needed)
2. pull the plug from the coil off the distributor and hold it with a pair of welding gloves 12cm (?) which is like three or four inches or something away from the aluminum in the engine block?
3. hook up a timing light to each plug wire (make sure to point it the right way) and crank the engine (no extra hands needed if you can reach)?
4. on this one i am pulling the lead on one spark plug, insert a spark plug an then clipping it to the aluminum engine block somewhere and cranking (no extra hands needed)
5. not totally clear in this one but i can make (would kind of like to do this) or buy a spark plug tester that would test each cylinder?
does that sound right?
> i think i wasn't totally sure i admit about grounding plugs. i guess i can ground to the body of the frame or i can ground to a metal clip attached the engine?
THANKS
Yes you can buy all kinds of testers for spark plugs, wires, etc...
Focus on one method and get it done before worrying about what comes next much. Check to see if your horn works, check to see if your headlights work (per previous post) or find a meter and check those fusible links with it.
