Thanks, one switch for both.Great job. That looks fantastic. Separate toggle for front and rear?
This is all for 75 and newer cruisers.
Then there is the heater control light, the rear side red marker lights and the license plate lights. That's all the lights I can think of. Someone want to come up with those?
Anyone want to comment on the selection above? I took as much of Yoopers input and tried to update it for the best selection there is at this time. My thoughts are you want the best lights you can get if your going LED. I'm sure some of my selection could be improved upon. I will say in my dealings with LEDs you want to have the same color light as the lens color. Otherwise your just wasting brightness and it will wash out. Back when I bought mine I didn't have a choice to buy certain lights. I only had the blueish white to go with. Will say though that I have yet to have a bulb failure in all these years. My lights get mud and water in them all the time and the LEDs keep working. SuperbrightLEDs makes a great quality product that will last. You can certainly find cheaper than them but your going to suffer in longevity in my experiences in LEDs.
This is for a 79 but it's a good starting point
The first number is the original bulb numer which should match up to most incandesant bulb charts. The other info is the part # from www.superbrightleds.com that I used as a replacement.
1975-1984 FJ40 TOYOTA Land Cruiser
(Straight from Sylvanias site.)
High & low beam headlamp
H6024
H6024ST Silverstar High Performance Lighting: the whitest and brightest Halogen
H6024XV XtraVision Halogen Upgrade: 3x brighter; 2x the life
H6024CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
67
Quantity: 2 white (front)
Product: 67 LED bulb $ 2.99 (each)
Options: White 2.00
Front turn signal
1156
Quantity: 2
Product: 1156-A30 Amber LED bulb $ 8.99 (each)
Rear turn signal
1156
Quantity: 2
Tail light / Brake
1157
Quantity: 2
Product: 1157-R24 Red LED bulb $ 7.29 (each)
Options: Wide
License plate
89 I used the 67 bulbs and they worked just fine
Back up light
1156
Quantity: 2
Product: 1156-W24 White LED bulb $ 12.99 (each)
Options: Wide
Front sidemarker (amber)
67
Quantity: 2
Options: White +2.00
Rear side marker (red)
67?
Quantity: 2
Options: Red
Step/Courtesy light
DE3425
Quantity: 1
Product: 3910-x6 LED Festoon bulb 6 LEDS
Options: White 3.70 or any other color
Headlight switch bulb
BA7
Quantity: 1
Product: BA7s LED bulb $ 0.89 (each)
Options: White +0.60 or any other color you like
Dash controls (in dash pad)
3022
Quantity: 1
Product: 3022-4 LED Festoon bulb $ 1.89 (each)
Options: White +0.95
Instrument cluster lights
194/168 (T3)
Quantity: 3
Product: WLED 6-LED bulb 12 VDC 6-LED Wedge Base bulb (194/168 type)$ 2.99+
Options: 2 green for turn signals, 1 blue for hi/lo beam
Quantity: 2
Product: WLED 5-LED Wide Angle LED bulb 12 VDC 5-LED Wedge Base bulb (194/168 type)
Super Wide Viewing Angle bulb uses 4 radially mounted LEDs aiming out the sides and one High Flux LED on top $2.79
Options: White +1.50 (for Instrument lights)
gcrump01 said:Has anyone found an LED that will work in the under dash light (not the one in the dash pad). The one that mounts under the dash - I think it is called "heater control light"??? The 3022 festoon from superbright is too fat to go inside that narrow metal case.
