FMC80
VAF connection/Grounds/fusible link/air, fuel, spark/efi relay installed? You may have removed it during your maintenance. Just rambling off the obvious that you may have overlooked.
Check, check, check. I am double checking a ground 1st tomorrow. Then I’m going to check that spark if I can get my wife to held for a couple minutes. If spark, then I’ll check the distributor and confirm that it’s not 180 off.VAF connection/Grounds/fusible link/air, fuel, spark/efi relay installed? You may have removed it during your maintenance. Just rambling off the obvious that you may have overlooked.
Say what?
We’ll I’ve never owned a belt tension gauge before so I used the FSM to guide my purchase. The Burroughs style one was the only one I could find. Seemed straight forward to use.
Not sure if this is a typo but the plug gaps should 0.8mm. If you have yours at 0.3mm then you likely are not getting a decent spark.So on to spark. I did just replace every component of the spark system….new Toyota plugs (I checked gaps were at .30). New plug wires, new distributor cap and rotor. New coil. Hmm.![]()
He actually wrote .30 not .03
Well I kept on going…Wow, I’m not being very clear tonight. I’m gonna go have a beer and watch the Olympics with my kids. Tomorrow I’ll try again.
It worked fine, but it is much larger than I expected, it just barely fits for measuring the belts.I'm sure it's a great device. Nothing wrong with it. Just never seen one. I also have yet to look at the Toyota fsm.
Oops. I was not being clear again rushing along. This is my default mode when I can tell my “cruiser time” is bleeding over into family time. This is never a good thing g in my household, as it cause some bent feelings around here.Not sure if this is a typo but the plug gaps should 0.8mm. If you have yours at 0.3mm then you likely are not getting a decent spark.
I’m compiling a list. I’m in the garage as we speak and the truck is waiting for me. Here we go.There’s something simple you’re missing/overlooking. Have you verified your plug wires are in the right order and ignition coil wire are seated fully? Do you have fuel (lol)? Wonder if it’s your fuel rail/injectors.
I’m sure others have better ideas than my ramblings.
Yup. Just tried jumping with my trusty Subaru, almost fired up. I’ll pull the TB and stop crying.Low compression? I doubt it but anything is possible. If you found your injectors to be loose/unseated then I’d keep going down that path. Throttle body will take you 69 seconds to remove and verify.
I know you’ll get it; it’ll happen today
All connectors are secure and correctly wired according to my EWD.Yup. Just tried jumping with my trusty Subaru, almost fired up. I’ll pull the TB and stop crying.
