Johnny is right on. Just so you know you can change that o-ring without too much hassle. Just take the retaining clip off and slowly move the shaft back till you can get to the o-ring. It does not have to move much to get to it. Be VERY careful, if you pull it back too far, it will come out of the front area it rides in, then you have to do a little more than just replace an o-ring.
Make sure you get the correct year's O-ring for yours.
Ex
Yes, be VERY careful not to pull the shaft out more than absolutely necessary. If you go too far, there's a thrust washer at the front end of the shaft (#14 in the pic above) that can fall down into the bottom of the case. Then the entire case has to come apart to fix it.
Wow! I've been trying to figure out if I could do this, too.
Tapage, you serious? You pulled the shaft out and then had to do a springover, rear disc conversion, AND take the transfer apart? I'm not sure if I have time for ALL that...
Seriously though, does that shaft want to shoot out, or can you CAREFULLY do it?
A slow drip is better than splitting the case right now, as I barely have any time to devote to the cruiser.
having it SOA makes working on the truck SOOO much easier. I did mine when it was stock and my chest almost touched the bottom of the case.
I need to do the same thing on my 86.... how are you getting the idler shaft to come out just past the o-ring land?... how are you leveraging its movement?
Yeah this is an old thread but I'm still willing to learn...![]()
