LC200 & LX570 Rear Tailgate Light Dual Colour LED **Updated** (4 Viewers)
Hi Brendan
I am interested in getting one of these for my LC200 2012 (Update) Sahara in grey colour please. Thank you.
Hi all
Purchased one of these for my 2017 Sahara. Very well made.
For the life of me I cannot get the tail gate switch out. No way I can push it out from the inside. Using trim kit removal levers from the outside I have it very loose but cannot pull or pull/push it out. I started applying force and heard a loud crack and the sound of plastic flying around inside the tailgate.
Before I resort to pulling the tailgate apart, does anyone have any ideas?
I did try to remove the plug and try to plug in the light leaving the switch in place, but can't quite get my hand in the right place.
Thanks
Nick
Hi Nick
It is only the center or “moving” part of the switch that you push out from the inside of the tailgate, not the entire switch housing including the outer flange section. It seems counterintuitive but if you push and wriggle just the center part where the plug joins the switch it will pop out and leave the outer flange section still firmly in the tailgate. Hope that helps. I confirm that it is a well-made awesome bit of kit once you get it connected and working!
Cheers
Hi Nick
Cheers
Thanks cube. All sorted.
Hi all
Thanks
Nick
Now that cube helped me know how to remove the switch, it was a 5 minute install.
High-quality kit. Great service by Brendan. Unless you really NEED to make it yourself, I suggest dropping the $ for Brendans kit. You also then have your spare blank panel.
Just seen you're post.
Thanks Cube this is correct.
If you require any assistance please send me a PM and I'll provide any further information and a solution.
Just received my light from Australia, super nice quality and craftsmanship. Installation was a breeze. Thanks so much for offering these. A great addition to my new rig!
Thanks Brendan. Received my light. It took 5 minutes to install and looks great/works great. Hardest part was figuring out how best to remove the lift-gate close-door button. I was able to stick my phone in the hole and take a picture which showed where the tabs were and where to push for removal. Easy.
Hi Brenden, please let me know how I can purchase one in black for my 2021 LC with power lift gate.
thanks!
Would like one in light gray for 2015 LX570 (US). Please lmk. Thank you.
is this one? I can’t take it off 😂
I have been making these up for 200 Landcruisers in Australia and selling them.
I sell them for $190AUD in Australia if anyone is interested message us and I can post to USA to your location for 225AUD
Payments threw PayPal
Please PM and I will reply ASAP.
Only 1x (Light Gray) Interior panel colour
I do have a few black covers left also
**Fits 200 Series Landcruiser Sahara 2012-2019 (only) with electric rear lift up tailgate.
Plugs into factory wiring No cutting, soldering or running extra wiring or fuses.
Install it yourself in under 2mins!!
Rear 9w Led light operators when rear lift up tailgate opens also has over ride switch on/off to have the 9w Led Light off when tailgate is open.
9w Cree LED High Quality
Operational Hours = 50,000+ hours (more than 5 year continuous use)
Aluminum Casing to assist with heat distribution
120° degree angle Led.
Fused through factory vehicle wiring.
Blue illuminated push button switch.
Fitting Instructions provide with item
*Light times out after 20mins to prevent battery going flat if left open. Can be reset by simply opening and closing up liftup tailgate again
*Light switches on automatically when lift up tailgate is open and can be overridden so lift up tailgate is open and light is switched off
Hi Brendan
Hi Brendan , great piece of kit. Chasing one for my VX in grey if available. Cheers Clemo
Hi all
Thanks
Nick
Nick.
I found the best way to remove the switch fixture is to reach into opening and feel around the perimeter of the opening and feel for at least two tabs. Carefully push them out and fixture will easily be pushed out.
Don't feel like the lone ranger. I broke mine too during my first attempt to remove it.
I love mine, I couldn't live without it. We've had it in our 2019 LX570 coming up on a year now, I use it every single day with no issues.
Any way you can make two of these with a button to open the back
Would it be possible to also include a button to open the back tailgate?
Hi Brendan,
does the blue light on the power button go out when the boot is closed? I hate having light in the interior while driving at night, especially blue. for some reason almost every cigarette to USB adapter uses them.
thanks!
Hi Brendan,
thanks!
Yes the blue illuminated switch goes off when door closed.
That is so true about the USB adapters
