Media LC 250 & GX550 Picture Thread (11 Viewers)
Photo/Video/Audio threads
Same issue for me. My 1Up fits in it fine, but the locking pin isn't quite long enough to work. I'm having to shop for different, slightly longer locking pins.
With my thule, the locking pin bolt is crushing the second wall. I guess I need to make a shim to go in there to prevent it from crushing.
I just used one of my wheel lock pins from one-up
This is the same thing I did as well.
I'm more upset about my fancy Factor55 locking pin not fitting after I splurged on it.
Finally drove on my first trail ever. Easy course, which I wanted. Mostly smooth with some bumps here and there. Reached my goal of getting to shoot.
Picked up this past weekend, just learning all about the different configs
I have a rocky mounts hitch rack - had to buy the XL bolt for newer model Toyotas for an extra $15. Working great now.
These fit the stock rims that came with the 245s correct?
Amazon's sizing is telling me it won't work..
Also did you get a 5th for the spare and if so did it fit without issue?
One more question - how's the road noise w/ those vs. the stock tires?
Yes, easily. You can fit even bigger tires on the stock wheels. Many here have. All over this subforum. Just look.
I don't know who would trust Amazon for tire sizing.
Fit great. Amazon likely just telling you these are not the factory size for that trim level.
The First Edition trim, Land Cruiser trim, and Gx550 Overtrail all come with 265/70r18.
Yes. I replaced all 5. Fits in the spare well fine.
I can perceive a marginal difference in both road noise and vibration/harshness (<15% increase in each).
In a 116T load rating and a relatively light weight, this is likely one of the softer riding A/Ts you could put on the 250.
Thank you!
