krusty 80 build thread (5 Viewers)
Los Angeles, CA
Finally its time to document my 80's history. It started with 227,827mi when I bought it. March 2018.
EBC brakes first off
Kumho 33" tires first
Painted stock wheels
Snorkel
lift kit OME 3.5 heavy front and 2.5 heavy rear
ARB bull bar with 12k smittybilt XRC gen2 winch
castor correction plates
removed viscous coupler
drive shafts rebuilt new OEM u- joints
Ultra-gauge
lighting;
baja designs sqadron pros
lp'9 pros
s2 pros
brackets front and back by yotateq for lights
denso cold start starter
bowfin cruisers roof rack
hudd expo battery and starter cable kit
rugged radio rm-60
complete engine rebuild at 240k - photos below
injector testing and rebuild
all new hoses, cables replaced heater valve
hudd expo EGR bypass kit
wrapped EGR loom with heat shield
oem distributor
oem coil pack
oem air cleaner hose
PHH done
thermostat & radiator
OEM dash light bulbs
VC 120 charcoal canister
oem fuel pump & filters
blue fan clutch with mod
windshield sprayer valve
wits end modified windscreen nozzles
oem AC compressor w/ expansion valve
yellow box speedo correction
pin 7 mod and CDL switch
replaced front seat motors including caps and gears
sunroof seal fix with bicycle tube
new seat foam and leather by vendor in san diego. + steering wheel wrap
OBX racing muffler and resonator along with new cat & o2 sensors
dobinsons drawer system with fridge slide
4x4 labs rear bumper
huracan fabrication tailgate storage
White knuckle sliders 1" wider @ 10 degrees.
FN countersteer type X wheels
35" falken wildpeak at3
LCP front sway bar disconnect kit
LCP HD rear sway bar links
LCP T-Case selector extension
Whiteline HD sway bars front & rear
Cruisin off road Transmission and Transfer case skid plates
Heat/ sound insulation on all door panels and entire floorboard
all new glass trim/ OEM
replaced master window switch
window tint 20% on all side windows
new ceramic coated windshield (50%) + limo tint sun strip.
spartan auto locker in the rear.
yukon 4.88 gears
front and rear diff bearing kit
extended brake lines all around
trail gear diff armor
depo headlights
tom woods double cardan front d/s 120wall DOM.
new oem window moldings
new oem door and body weather stripping seals
new oem glass runs all doors
ABS delete & Wits End ABS sensor plugs
wilwood Proportioning valve
Looks great. Did you do the motor rebuild yourself or farm it out...if sent out, who did it?
Nice looking truck and upgrade list.
The engine rebuild looks good. Can you give some details on what you did to the motor? Did you balance and blue print? Over-sized pistons? Port and polish? Thx
Great looking rig, nice work.
heres the motor info @lasoundguy & @Road Apple *edited to reflect that K&H imports did the work (they sub the motor rebuild out to their local guy)
part list;
complete timing component kit
safety pistons with rings
safety main bearings
toyota rod bearings
safety thrust washers
ACL pin bushings
iron exhaust valve guides
misc parts and plugs..
work;
clean and mag block
deck block - .010
bore and hone .020
clean inspect and polish crankshaft
resize 6rods
R and R pin bushings and hone to fit pin
balance rotating assembly
valve job
pressure test head
remove and reinstall valve guides and hone to fit
surface head .008
solid followers R and R cams and trim valves to adjust valves
mild porting on intake and exhaust bowls
more parts;
spark plugs
fuel filter\
water pump
coolant thermostat
coolant thermostat housing
new coolant hoses
transmission filter kit
engine motor mounts
transmission fluid flush and replace
injectors;
service and clean injectors.
attached photo is the analysis worksheet from the injector test.
phh done along with throttle cable, kickdown cable, every vacuum hose and more misc under the hood components....
new denso radiator
new A/C compressor and expansion valve to get my cooling system up to icy cold...
Which smittybilt winch did you install? X20 or xrc? Also did you need any spacers or brackets to install on the ARB?
It significantly reduced outside noise and also keeps the center console from getting as hot.
Looks good. Good motivation to do this project. Read an old thread yesterday about heat becoming an issue on long trips. Their answer was to problem was to,
“Order heat insulation to cover the transmission tunnel to hold the temps down.”
“Put some adhesive heat shielding on the oem heat shields above the downpipe, and both cats. I also put some in the passenger side footwell & transmission tunnel. works very well...much more comfortable”
They also mentioned that sound deadening along did help their heat soaking through into the cabin much. The heat shielding was a big improvement.
Might be overkill, but I am thinking of adding heat insulation to the sound deadening.
Yes so I used Noico 80mil, the transmission tunnel I went with 3 layers overlapping and driver/ passenger floorboards 2 layers overlapping.
Inside doors, rear floorboard, quarter panels and inside the tailgate 1 layer.
It really helped with temps and of course noise. there's a "thud" when the doors close now...
Hey there. Noticing the ARB bull bar turn signals have been replaced with aux lighting? Or did that come as an option w your ARB? I need more light in the dark AZ desert night but really want to keep mine looking as clean/stock as I can. Thanks or any info you got! Charlie
Those lights are (2) baja designs "S2" lights. With the flush mount bezel, total of (4) I did, 1 set clear and 1 set amber, depending on conditions I use the different colors.
The incorporated ARB light, turn signal, whatever it's supposed to be, I didn't like it. Had to notch the slot to make it a little wider to fit both of those.. if you just put (1) light then there would be gaps on the side..
