Doesnt sound to strange, sounds like the kaiser just uses the older smaller journal. If the Kaiser is 45mm jounal than you need LM603049/LM603014 (we stock bulk in Koyo) This is the same carrier bearings as on 90 & older rear or on 8" 4cyl diffs. If it is 50mm than you need 32010x
We got the carrier out.
Installed the crown? gear.. and where ready to swap out the bearings.. But found the diameter of the Kaiser sleeve at the end where the carrier bearing sits is smaller than the OEMso we haad to order new bearings with the new smaller inside diameter, and the same outside diameter as OEM..
So needless to say I will now not be able to stay OEM with the bearings.. We ordered SKF brand since it was the only available to match the size! Is SKF any good? :whoops:
