Any chance you can share the best place to put the borescope when looking for the valley plate leak? Pictures would be super helpful for us vocabulary challenged folks.
With foam in places, makes a bit harder. I, go down under front of intake manifold/air pipe/throttle body area. Look at water pipe. to valley plate and water pump o-ring. Also below, where there's often a puddle on block. I also, look down both side a long valley plate seal to block. The rear area is accessed, from back of intake manifold.
I have a 6mm camera on 3' snake w/360 degree directional (hard to control) borescope attached to iphone LED. It would be easier with 180 degree directional. 8mm 180 degree. Has better resolution, sold on
Amazon.
I look until coolant/crusty pink seen at minimum, or untill all areas of valley seal and water pipe viewed.
I can't find anything about it in a quick search but vaguely remember seeing a product that was a plasma-cut piece of steel that fit under the bolt heads but on top of the valley plate around the perimeter, thereby stiffening the aluminum between the bolt heads. If the top of the sealing surface is flat enough this could help address that issue.
I will say though, one major advantage to FIPG is that it inherently adjusts itself to uneven sealing thickness after torquing the plate, before the FIPG has set up. I think you are right that a groove could help a lot.
I also seem to remember reading an analysis online that this may be caused by a couple places where the FIPG wasn't applied correctly.. like the computer-guided machine leaves a couple spots that are too thin. I can't remember where I read that, but they had pretty solid logic and lots of pictures of separated valley plates as evidence. I have been paying attention to this as it's so common, though I'm one of the fortunate ones with no leak at over 200k miles.
Just making more rigid, with steel border. May be helpful. But wouldn't give the V groove.
The V groove IMHO is needed. Which a resigned casted aluminum valley plate could address both. I use a Machine shop now, that can make the molds for prototype. He can then make small batches. Of 10, 20, 100, etc., a one man shop. To spread cost of prototype. Run of 100 may make reasonable.
For now, for me. It's a PM. Unless I see a lot of interest, to make worth my time and expense.
Here's example, of V groove seen in 100 series 4.7L
This is new water inlet on 4/7L. We use 1282B in V groove. Interesting. New they come with FIPG in the groove. It act just like fresh FIPG 1282B, out of the tube. Squashing out the sides, when torqued down. These water inlets, only have two bolts 8mmx1.25 torqued to 13ft-lbf holding down a very thick and small body. It never leaks.
We fill the V groove with 1282B FIPG and use soapy (dish) water the new 0-ring. Install to 13ft-lbf. Done never a leaks.
Interesting. It uses same O-ring. But just needs 1. It is in a very nice heaver and perfectly sized groove. They also never leak when properly installed, with soapy water.
Why Toyota went away from a proven design (thick with V groove), IDK. Considering the size of valley plate, seems a mistake IMHO.
