Hi together,
I'm new to this board, so first of all I'd like to intorduce myself: my name is Dmitry (or Dimitry), born in Ukraine (former ex-Soviet Union), living in Germany. I'm driving the toyotas since 15 years - HJ60 (sold), K/LJ73 (broken apart), KDJ95 (current)
and now since couple of weeks I've became on owner of a HDJ100.
The J10 is in a good shape, has approx. 200TKm (125TMiles), with minor problems such as bit rusty frame, rusty tailgate and since couple of days - a non-working Navigation. In real life I'm a developer of navigation systems (f.ex. in modern BMW, Audi etc there some parts of my work) - so I can compare and know for sure, that the Navi in J10 is, let's say, "no more state of the art"
Nevertheless, I'd want the system to work properly now - even if i'm planning the conversion to non-Navi dash later.
Couple of weeks ago it was full functional, I was able to enter the address and start the guidance. Then I've seen some artifacts of the screen, as if the graphic card is faulty - but it continued to work properly. Artifacts disappeared, I drowe home and when I started the car next day - the navigation did not start anymore. If I press the three top left buttons (Voice, Dest, Menu) it just makes a beep and nothing happens. I've did a test with an engineering menu, soldered the pin 60 in the main unit, made a reset of the system - it doesn't help. The diag function shows that the navi has no problems,
but if I go into the system menu and try to start the navigation test - it doesn't go into the test, just nothing happens. Same about nav-related functions in the Info menu - they exist (f.ex. maintenance, calender), but if I try to enter these - nothing happens.
Sometimes, if I eject a NavDVD and then reinsert it - I get a picture with lot of artifacts, showing that the DVD is being loaded
and then after a minute the screen becames black.
Unfortunately I have no possibility to get a refernce nav.unit to test and bying it is not an option - as I'we said, I would modify the dash to a non-navi version later, as soon as I find the climate controls from such car.
Is it possible somehow to check, if the navigation unit delivers a picture? I'm trying to locate if the problem is in nav.unit, wiring or HeadUnit. How should I proceed, do you have any hints / ideas?
Thanks in advance,
Dmitry
Thanks in advance,
Dmitry
