Is this a good buy?
  • Thread starter Jackson Hanes
  • Start date
  • Watchers 9
J
Jackson Hanes
Iowa
Extended shackles raise the truck half the added length, but don't fix worn out springs. It's a temporary fix to lift. If the springs are flat or near flat, get new springs. If the shackle angle is greater than 45*, get longer shackles.
If you want a lift, get new springs. Shackles are a band-aid and usually give you subpar shackle angles unless correcting for longer length springs.
So should I install a lift kit, and then install shackles if they're not at a desired angle?
Sorry If I sound like a moron, probably not hard to tell. Not to sure what I'm doing, just handy with tools.
mattressking
mattressking
10 digits to freedom
Idaho
Yep - if your intention is to raise the vehicle, whether for looks, fit a bigger tire, looks, more room to flex, looks, or brag to your friends, the method is lift springs. Stock length shackles are fine for 2.5" lift but if you go with 4" (from skyjacker) you'll want extended shackles.
I know I said other brands are better, but for simplicity sake, best to give a ring to @cruiseroutfit and they will set you up with a 2.5" lift that just needs to be installed. If you need more than 2.5" you need skyjacker or rough country springs or something custom.
J
Jackson Hanes
Iowa
Shoot, looks like I have to return the shackles then. Thanks for all the help!
DSRTRDR
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
I’ve researched this, and I will probably go with a skyjacker 4 inch lift down the road. What I’ve found in my research is OME 2.5 inch lift is good for 33x10.5 tires while the skyjacker is good for 33x12.5 lift. Each one of those looks really cool IMO. OME is generally softer from what I’ve read, but skyjacker is pretty soft too apparently. I leaned rough country as well just because of the price, but I was informed that suspension is something you will keep for years or even decades, so best not to cheap out on it
4 inch is more tippy, especially if you add a roof rack but you can fit the wider tires. 35s will need fender cutting in both lifts
you don't want 12.5 wide tires, they wander more than 10.5s
DSRTRDR
DSRTRDR
buy the shackles from 4Plus (=@lcwizard here on MUD) - his stuff doesn't break (trust me, I have mangled every part of the suspension)
I recommend his anti-inversion shackles - I also recommend his U-bolt plate flip kit, while you're at it
Similar threads
H
Replies
14
Views
395
Hendlerj
H
fj4075nc
Replies
1
Views
186
brian
brian
J
Replies
20
Views
476
Steamer
Steamer
