It is the regulator that determines the voltage. Unregulated, they can put out over 100 V.
vosy said:A lot of the time the only difference between the 12 and 24 volt alternators is the diode boards. We run 24 volt alternators on 12 volt aircraft no problem. 12 volt alternators on 24 volt aircraft cause a lot of comm noise but work fine.
This statement implies that both 24V and 12V externally-regulated alternators are constructed the same Pighead.
And they aren't the same because Toyota uses different part numbers for each.
(So the alternators themselves are different too.)..![]()
Hey, who are you calling a Pighead?
^^^x 2
