Couldn't help it
Really though, I'm half-way through the front axle rebuild and I just have a few odd questions that I didn't see covered in the FAQ or any of the other excellent threads here on mud. All is going well, and I'll continue putting it all back without answers, but I'm curious about a few things.
First, I had no need for the 54mm hub socket (though I had one courtesy STLCruiser). Specifically, both hub nuts were so loose I could remove them by hand (after straitening the 'star' locking tab). Is this normal? I did check for play before removing the tires, just so I would know what to look for when I'm done. I was able to 'wobble' both front tires top-to-bottom about 1/8" after lifting the truck.
Second, how do I remove the four steering arm studs on the bottom of the knuckle so I can install the new torx head studs that CDan sent me? It looks like I just grab them with a vise-grips (or an actual stud remover) and slowly twist them out - is there any particular method? Also, is there a consensus on whether lock-tite should be used on the new studs (the threads all ended without a definate consensus - but they are all old, so perhaps there is a concensus now that hasn't been linked)?
Third, my inner birfs look fine I guess, but after cleaning I noticed there is a burnt looking circle about every inch around the outside of the ball. I didn't see this in any of the photos in the FAQ or elsewhere. The marks did not come off by soaking in cleaner (fuel equivelent, but less flammable). Should I try to remove these marks? If so, how? I can't feel them, I can just see them. If it matters, my birf soup was not as bad as some photos I've seen here on mud, but it was pretty soupy. First pic below is the PS, but the DS was about the same. The burnt looking marks are on both Birfs and look identical - almost factory
Fourth, in the second pic below, on the backside of the outer birf (where the sweep seals rub) I notice there are some rough spots that almost look rusty, and other spots that are black (like factory overspray). Should I try to smooth out these areas - if so, how?
Finally, what is the deal with the pink paint mark on the end of both outer axle shafts (see third pic below)? I guess I really did get the
package
