FJ40JOHN
After all the blow by issues with my original motor (overpressurising the crankcase), I dropped a running motor out of an 85 in my 84.
Now I can't get it to start!
Hooked up the distributor (DUI HEI) with the flywheel at TDC and rotor pointed toward #4 plug. Fuel is getting to carb (throttle linkage isn't installed, so working by hand). Motor spins, but won't run. I occasionally get a pop that sounds like it fired on a cylinder, but won't keep going. It will backfire out of the carb when given enough gas.
I've played with timing (spinning distributor), and advanced (turning distributor clockwise) seems to be better, and going the other way, even worse (no pops at all).
I clearly have no idea what I'm doing...
No accessories are connected, this is basic as it comes. No vacuum lines (planned desmog) just want it to run...however poorly, before I do the rest.
Where do I start?
Where do I start?
