indycole
GOLD Star
- Thread starter
- #81
I installed Tow Points and RLCA Skid Plates from @reevesci this week. The quality and service from Trail Tailor is top notch.
Even though these were minor modifications, I came away with some new lessons. First, I learned that my $35 torque wrench is wildly inaccurate after breaking one of the stock screws for the tow point. I had it set to a torque of 79 ft-lbs and it was probably torque-ing closer to 120 ft-lbs. I replaced the stock screws with some M12x1.25 55mm screws with a bit of blue loctite. I also picked up a Precision Instruments 1/2 Drive Split-Beam torque wrench and torqued the new screws to spec. Extracting the broken screw wasn't too bad as there was enough thread left peaking out of the frame that I was able to use some needle-nosed vise-grips to rotate it on out.
I also encountered some challenges with the RLCA skids due to operator error more than anything else. First, I had trouble getting out the RLCA bolt and then realized I was trying to loosen the bolt head instead of the nut. Second, unbeknownst to me my driver side RLCA housing had already taken a pounding and the skid would not fit over the housing. Hammering didn't help but I was able to reform the housing with some large vise-grips. I drilled a couple holes, installed the thread-tapping screws, and the driver side was all done. For reference, I'm going to powder coat these at some point but I wanted to get them fitted for an upcoming trip and the powder coating machine I use at a local shop is out of commission for a couple months.
The process was the same for the passenger side except that the RLCA itself was pulling toward the rear of the vehicle by about 1/4-inch. I tried various means of leveraging it back into place but couldn't provide leverage and install the skid simultaneously. Eventually, I used a gigantic ratchet strap that wrapped around the rear part of the RLCA and attached to the frame around the middle of the truck. I ratchet-ed with one hand and held the skid + slid the bolt back into place with the other. All done.
Finally, since I was in the vicinity, I lathered up the KDSS valves with marine grease.
